Results 5,121 to 5,130 of 5286
November 20th, 2019 11:52 AM #5121
November 20th, 2019 12:11 PM #5122
^brake fluids are hygroscopic (absorbs moisture in the air)..this device helps the user assess how much water is in the brake system..water corrodes the metal components of the brake system of any vehicle
When theres too much water on the brake fluid..its time to change to avert corrosion
It's not the job of this device to detect corrosion but to prevent it with due competence and diligence from the owner
- Jun 2005
- 3,774
November 20th, 2019 12:19 PM #5123Fuel filter can be changed outside every year. Mura lang naman yan.
Brake fluid, change every year or 2, depende sa budget. Ideally every year. Preno kasi yan.
ATF, yours is a sealed type kaya wala na dipstick. But it can still be replaced. Drain bolt lang naman and then there is a filling hole. Pwede rin dialysis. Make sure the amount drained is equal to amount filled.
Brake pad, have your mechanic visually inspect it. Chances are, manipis na ito. So replace mo na lang. I heard brembo pads are cheaper than casa originals.
I DIY maintenance of my cars so i do the above maintenance myseld, depending gaano ako kasipag and need the exercise.
Sent from my MI MAX 2 using Tapatalk
November 20th, 2019 12:28 PM #5124
fuel filter - sa monty ko 20k kms but nung sinunod ko dami dumi, so i replace every 10-15k kms.
atf - as long as di contaminated para sa kin and di pa iba kulay.
brake fluid - same din but ako i use syringe to replace the one in reservoir if ever mag iba kulay.
brake pads, depende sa gamit yan. visual check.
- Feb 2008
- 898
November 21st, 2019 09:25 AM #5125Thanks sa sagot. I will do those maintenance requirements by installment. First, aside as regular change oil and filter ko for the 35k pms. Isabay ko ngayon yung change of fuel filter. Then sa 40km pms, I will also do oil differential change, then as 50km pms, gagawin yung atf change. Para hindi mabigat sa bulsa. Ok kaya yun?
November 21st, 2019 09:27 AM #5126
- 52,731
November 21st, 2019 09:33 AM #5127
- Feb 2008
- 898
November 21st, 2019 11:07 AM #5128
- 52,731
November 21st, 2019 11:18 AM #5129
November 22nd, 2019 05:14 PM #5130
good day sir dati ganyan din ako pero after considering everything ang buhay natin
hindi pedeng palitan at sir i-condition mo narin ang sarili mo sa gastos talagang ganyan
milyon ang halaga ng ride mo. nagset aside ako unti unti ng pang PMS para pag dating ng
sked PMS konti na lang dagdag ko. gulong sir will set you back 30-40k handa ka na rin
in the long run sa bulsa lang masakit sa ulo wala. just a piece of my experience
at tama si drd mineral oil will do basta consistent lang ang palit every 5k hindi ka naman
kuma-karera
high idle RPM at engine start
