Originally Posted by
bert032984
hi sir,
pls have a check to the expert, brake issue yan sir.
yung sinasabi ng toyota service ang tawag doon ay BED- IN PROCEDURE, nagawana po ba nila ito? at ang tanong nagawa ba ng tama ang procedure? you nid to check it to the DMT- Diagnostic Master TEchnician nila. nagdadalawang isip ako sa qoute mo na "NAGSLIDE NG KUNTI ANG PAD", ganito po sir ang gawin nila, makitanong sa DMT ng toyota service ang Brake pedal height & brake pedal reserve distance ng sasakyan nila(actual and standard value), pacheck nila if may brake fluid leak, pacheck nila ang condition ng Frt brake cylinder assy at rear brake cylinder assy, ang condition ng pads & shoe, & lateral at run out ng frt disc. also pls include nun brake system thru GTS checking kung may Diagnostic trouble code.Kung ang lahat ay within tolerance value, sir magisip isip po tayo bka naninibago lng tayo sa design ng bagong toyota fortuner, alam natin that it is a full model change.....thank you & i hope makatulong saiyo sir.have a nice day.
