Results 101 to 110 of 127
August 30th, 2007 10:47 AM #101
Ferno makes product for the ambulance and funeral industries. I like browsing through their website.
Stryker rocks. Even on loose soil/dirt, the stretcher does not bog down or dig in. Tested na sa NAIA air crash drill earlier this year. :D
- Jan 2007
- 45
August 31st, 2007 07:49 PM #102ganun! well okay at least i saw their products. Doc, saka ko na ipadala pic ng ambulance namin kasi wala pa mga side signages.
- Jan 2007
- 45
September 3rd, 2007 08:54 AM #103doc otep,
whats the proper oil viscosity for the commuter? the manual says 20W-50, 15W-40, 10W-30 or 5W-30, but it continually states that "if we are to use SAE 10W-30 or a higher viscosity engine oil in extremely low temperatures, the engine may be difficult to start, so SAE 5W-30 is recommended".
some engile oils have fuel saving capabilities according to the manual, what are these? it did also mention of a "Toyota Genuine Moter Oil" is it available locally?
stryker
September 3rd, 2007 11:36 AM #104
I think the proper viscosity depends on the temperature of your working environment.
For the last oil change we used Castrol CRD (mineral based oil in the green jug). I forgot the exact viscosity but it was within the recommended specs for local conditions when I cross checked with the owner's manual.
- Jan 2007
- 45
September 3rd, 2007 12:13 PM #105Thanks for the information again doc. So we would be using SAE 20W-50 or 15W-40. Still waiting for your preventive maintenance forms or checklists. I sent you too a sample from canada.
stryker
September 3rd, 2007 12:16 PM #106
Yep. I'll send them to you when I'm using the desktop PC. I'm running on a laptop now. Thanks for the e-mail!
- Jan 2007
- 45
- Jan 2007
- 45
September 4th, 2007 04:29 PM #108Doc, problem! Advise naman diyan how to disinfect/sterilize the ambulance after transporting a patient with suspected meningococcemia. We just transfered out one a while ago. Would it be just the same as for other highly communicable/contagious diseases. In ambulances what is the difference between cleaning, disinfecting and sterilization. Thanks again doc. Meron din pala sa tsikot "SALAMAT DOK" tulad ng saturday show sa abs-cbn. wag lang tulad sa wowowee hehehe.
stryker
- Jan 2007
- 45
September 4th, 2007 04:43 PM #109doc, emailed you too baka duty ka pa. anyway zonrox lang muna ginamit namin sa mga accessories at full airing ang unit namin kanina sa araw.
September 4th, 2007 04:53 PM #110
We use Lysol (liquid, not aerosol) contained in a spray atomizer (e.g. those Everwing spray bottles from the grocery). And just wipe down everything using a shop rag (yung mga bilog bilog para pwede na itapon sa yellow trash can after).
For international standards, everything is supposed to be non-porous but the Grandia has fuzzy headliner. I think the Commuter uses vinyl so its not a problem.
For airing out, we drive with the windows open the the a/c recirculate lever in the open mode. Yes, we also soak the units under the sun (just make sure you take out all the perishables). We then spray the cabin with Lysol Aerosol.
AFAIK, cleaning is just ensuring that the surface appears clean (removing dirt and grime), disinfecting is cleaning by the use of a disinfectant (e.g. Lysol). I don't think the interior of the unit has to be sterile since amubulances are working in the field which is technically 'dirty'. All sterile items (e.g. ET tubes, scalpels, sterile gloves, etc.) are in sealed containers anyway.
Di ko alam about sa miata. But I was able to help my uncle acquire a unit para sa pinsan ko kasi...
6th Gen Mazda MX-5 Miata
