Originally Posted by
vinj
I see. For the price, i won't pay that for an old Super Grandia. I'd consider only if it's super pristine and i'd really (as in really) want one (which i don't). Speed isn't much but it has good gear ratios to give you good climbing power, and the ride comfort is indeed much better than the current Grandia due to the coil spring rear suspension. Check also the service records to make sure fluids and filters were changed regularly; it may be low mileage but that will be all for naught if it was not maintained regularly.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
