Page 137 of 238 FirstFirst ... 3787127133134135136137138139140141147187237 ... LastLast
Results 1,361 to 1,370 of 2379
    Aug 2017
    #1361
    Gas up worth P2.2k Phoenix bawang la union. Diesel is P39.89 per liter. May discount pa na 55 pesoses
    Sent from my iPhone Xs Max using Tapatalk
    #1362
    Happy Easter Monday!
    Apr 2019
    #1363
    Quote Originally Posted by moyg View Post
    Mga bossing ask ko lang what is the best petrol diesel in terms of performance, quality.. currently using v-power diesel for more than 2 years now pero mabilis masunog but performance is good. thank you.
    #1364
    Quote Originally Posted by Escape101 View Post
    what do you mean by "mabilis masunog" ?
    Apr 2019
    #1365
    good pm sir, madali bumaba ung diesel, madali maubos, i'm thinking ung diesel sa petron daw mas matagal masunog? Salamat.
    the term nasusunog... is just not based on facts.
    diesel engines have more precision injectors than petrol or gas engines because they use higher pressures.
    consumption depends on engine demand, colder temps on the climate controls. slightly heavier foot because natatae or because highblood or diabetic. increased speed because reacting to a kamote. or simply idling more because of the traffic.
    Apr 2019
    #1367
    thank you mag sir
    Feb 2013
    #1368
    Not sure if it's because of the cheap 95 octane gas that I use with my Subaru XV, pero sabi nung SA nung nagpa PMS ako is usually daw cause ng parang may tumutunog sa baba ng car during initial acceleration is yung cheap gas. Usually daw rinerecommend nila mga customers nila na mag change brand muna and see if it fixes the issue. Any truth to this?
    Quote Originally Posted by kevindd992002 View Post
    sa ilalim? probably not.. the combustion takes place sa itaas. also sa itaas yun camshafts which are sorta affected by bad oil. sa baba yun crank shaft na puro oil lang naman nag aaffect.
    #1370
    I'm getting around 10% less mileage on Caltex diesel vs Petron and Shell. Same average speed, route & conditions. Has anyone else noticed this? Butt dyno also feels a bit less power.
Gas stations with cheaper fuel prices [continued]
