Page 10 of 12 FirstFirst ... 6789101112 LastLast
Results 91 to 100 of 111
    Sep 2013
    #91
    Quote Originally Posted by LancerA174A View Post
    Same problem with my mom's iPhone, pati na din sa Xperia ko, 1 bar lang signal sa kanya wala talaga. Biglaan na lang ganyan Globe, dati matino naman kahit saang sulok ng bahay pwede ako maka tawag or maka text.
    for android users you may change the the network mode to GSM by simply select connections >more networks >mobile network>network mode > GSM. voila!!! hope it works
    Feb 2012
    #92
    Quote Originally Posted by kimbon View Post
    Kahit yung mga lumang mobile sir hirap din samin
    Mar 2004
    #93
    Globe must've turned their transmitter a few degrees or there's something new blocking your signal path from transmitter.
    Oct 2009
    #94
    Bro, I used Rsim on my IP5 (which is locked to globe) to use a Sun sim. Is it possible to use globe sim again using the rsim tray and rinsert sun afterwards?
    pwede po tanggalin ang r-sim.at ipasok ulit ang globe.kung ibabalik po ulit ang sun.ilalagay nyo po ulit ung r-sim
    #95
    ^cant do that, sectoral antennaes are fixed. Either the orig BTS serving you were turned off or its a network related outage causing your phone to connect to the next cell site with lower capacity. Take note not all sites have the latest technology, some of the sites are still in 2G and backhaul is in T1/E1.
    Oct 2009
    #96
    Quote Originally Posted by kyle_armie View Post
    Ask ko lang po ung iphone ko kapag nasa bahay walang signal pero kapag nasa labas ako meron pero may time na hindi din nagsesend yung messages. Pinacheck ko ung antenna oks naman daw baka baseband ang problema? Magkano po kaya parepair nun?
    kung baseband problema niya sigurado unknow na ang imei niya or serial number.
    anong iphone ba yan.try mo din i off ang cellular data.or 3g
    Jun 2015
    #97
    Quote Originally Posted by jaypee10 View Post
    Iphone5 po. Natry ko na ung hard reset tpos nagreformat na din ako.. may spot lang sa house na magkakasignal pero unstable. Before oks naman ang signal ng globe sa house tpos among sa tatlong telcos globe ang pinakamalakas pero ngaun siya na ang pinakamahina...
    Feb 2016
    #98
    baka may maitulong ako sa inyo tungkol sa kung ano mang problema nyo sa smart phone nyo.ako ay cellphone technician.
    post nyo lang problema nyo.kung block ang pattern lock nyo at baka ma DIY nyo ma iguide ko kayo kung pano tanggalin ng magic touch yan. para hindi na kayo mag punta sa cell shop.
    post nyo din ang sira ng mga tablets,cellphone. nyo para mabigyan ko kayo ng idea kung magkano ang tamang price na sisingilin sa inyo sakali mang ipagawa nyo sa technician gadget nyo..
    ex,ayaw mag charge ang tablet ,mag cha charge lang pag ginalaw ung charger .
    tanggal lang sa hinang yan..pwede pang hindi palitan ng charging pin hihinangin lang,
    tamang labor dyan 150 ,
    May tanung lang me, dapat LTE enabled ba ang smart phone para makagamit ng Smart LTE? Please answer and enligthen me about this. Thank you!!!
    Quote Originally Posted by omniversatility View Post
    Yes, your phone must be LTE capable.
    Feb 2005
    #100
    what about the sim? shouldn't it also be LTE capable? or is he asking of an LTE capable sim to be comapatible with non LTE phone?
Cellphone problem..
