Results 81 to 90 of 111
August 1st, 2015 09:52 PM #81
^^ try nyo iset ang network mode sa GSM only. baka yung CP nyo naka set sa network mode na "auto connect" WCDMA / 4G at walang signal na WCDMA /4G la loob ng bahay. kahit saan lupalop ng pinas may GSM signal pang txt or call lang. besides network mode set as GSM consumes less power compared to auto connect mode
- Jun 2015
- 27
August 1st, 2015 11:35 PM #83
Fix yun sa iphone, cannot be set manually. Try turning on the airplane mode for a couple of seconds then turn it off as it will reset your network connection..
August 1st, 2015 11:37 PM #85
kyle_armie,
if your iphone is locked in with globe that setting isnt available it defaults to a very slow network of 2G which is EDGE (technically an enhanced GSM)Last edited by kisshmet; August 1st, 2015 at 11:44 PM.
- Jul 2010
- 844
August 2nd, 2015 12:50 AM #86
August 2nd, 2015 10:03 AM #89
August 2nd, 2015 10:45 AM #90
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
