Page 8 of 12 FirstFirst ... 456789101112 LastLast
Results 71 to 80 of 111
    #71
    problema talaga sa smartphone yang madaling ma-drain kaya nga balik na ako sa bar phone. isang charge pitong araw na
    #72
    Yup bro, go to Setting > Backup & Reset > Factory Reset.
    It will surely improve your battery life and the phone would feel like new again.
    Dont forget to back up first. Have fun!
    thanks bro. I'll do that when I get home tonight.
    btt was about to buy a new battery for this phone
    Dec 2009
    #73
    Quote Originally Posted by shelu View Post
    oppo joy here. bakit po kaya pag magdownload ako ng apps, palaging insufficient space samantalang 16gb ang sd card ko. tried following suggestions sa net, ganun pa rin.
    If the operating system of your smartphone is an android kitkat version then it will have issue writing to the expansion SD card it will save all applications you download in the internal memory of your oppo
    Jan 2013
    #74
    Depends on your phone's internal memory, or if your phone has the option to transfer app data to SD Card. Usually kasi half (minsan more than pa) ng internal memory nakain ng OS, yung natira na lang is pang apps. And even if you have the option to transfer apps to SD card, mag ooccupy pa din siya ng space sa internal memory.
    #75
    Depende nga sa phone's internal memory. Kapag mababa, palagi talagang mag-prompt ang "insufficient space". Some apps bagamat transferable sa SD card, still uses a certain amount in phone's internal memory. When and upon downloading, kailangan din ng malaking amount of space sa internal memory to sink-in or install the app you're downloading. You must take a look in its specs about the RAM and ROM of a smartphone. Mas maganda kung ang RAM mo ay 1GB at ang ROM ay 4GB or 8GB(mas better).
    Sent from my UP+ using Tapatalk
    May 2010
    #76
    ts magkano papalit neto? ipad mini. nahulog kasi ng anak ko e basag yung screen pero ok pa yung lcd niya pwede pa gamitin kaso basag basag na screen.imageuploadedbytsikot-forums1438407686.173583.jpg
    Jan 2013
    #77
    Quote Originally Posted by piscesboy View Post
    I think nasa 2-4K replacement iPad digitizer/glass. Try SST nag rerepair din yata sila ng phones and tablets.
    Jun 2015
    #78
    Ask ko lang po ung iphone ko kapag nasa bahay walang signal pero kapag nasa labas ako meron pero may time na hindi din nagsesend yung messages. Pinacheck ko ung antenna oks naman daw baka baseband ang problema? Magkano po kaya parepair nun?
    Feb 2012
    #79
    Quote Originally Posted by kyle_armie View Post
    Anung network. Mo sir kung globe ganyan din sakin pag sa loob ng bahay walang signal pag sa labas ang lakas naman kaya nag smart nalang ako
    Jun 2015
    #80
    Globe. Hassle lang talaga lalo na postpaid tapos nakalock in pa ko. May way kaya to para maboost ung signal?
Cellphone problem..
