Results 11 to 20 of 65
December 21st, 2016 07:28 AM #11
December 21st, 2016 08:23 AM #12
December 21st, 2016 09:04 AM #13
with diesel engine equipped cars and since the advent of electronic gasoline fuel injection, i have never heard of engine backfire. if you have, let us know what vehicle and what engine. also, with electronic fuel injection, i haven't heard of dieseling or engine running on with the ignition shut off, if you have experienced one, please let us know.
- 54,286
December 21st, 2016 09:12 AM #14it will probably result in a warmer passenger cabin. because the intake keeps sucking cool air from the cabin, warmer, outside air will come in.
it will probably be not an issue in places where where temp is cooler, but in the phils, it will probably be an issue.
like driving with a window open, even if partially.
December 21st, 2016 09:38 AM #15
- 54,286
BANNED BANNED BANNED
- Jun 2007
- 122
December 22nd, 2016 05:08 AM #17
That's only a myth. They are just using FEAR to scare you to keep buying overpriced paper filter. Did the "so called experts" showed you any Scientific evidence to prove their theory? May air filter din naman na washable na hindi oil type.
"If you don't control your mind someone else will"
2 ang maaring daanan ng air papasok sa engine, sa Air Filter at EVAP Canister Vent.
I'm using Washable Oil Type Air Filter for more than 15 years and I never experienced a single engine failure. Once lang ako nagkaroon ng konting problema noong first time kong linisin at magrecharge ng oil sa filter. It's either na di pa masyadong dry yung air filter nang nilagyan ko ng oil or baka sobrang dami ng oil na nailagay ko. I'm still using the stock MAF Sensor until now. A Cheap Generic Scantool will give you access to MAF Sensor PID.
MAF PID * hot idle no engine load
4.0-5.1g/s
0.52-0.67lb/min
0.6-0.9 DC Volts
December 22nd, 2016 08:31 AM #18
- Oct 2015
- 1,054
December 22nd, 2016 10:12 AM #19There is truth to it naman. Given the same surface area, better flow will always come at the expense of filtration. Di naman masisira agad yung engine but definitely bigger particles will get past and cause more wear. Impossible to know by how many kms it will reduce engine life but to be conservative, the potential to do more harm than oem is there. While you may be able to have run the engine for X km without problems, it may run for X + 100TKms if on oem. That's not even accounting for oil on the maf sensor.
The only benefit I see that attracts most people to K&N is the promise of lower cost. Most oem filters flow more than enough air for the engine.
December 22nd, 2016 10:27 AM #20
I purchase K&N drop-ins precisely because it's reusable and pays for itself in the long run.
As for MAF sensor issues, we've been using K&N since the 90s and so far i've only had one MAF sensor problem and this was with my 2007 Corolla at 120,000kms. I doubt it was due to oil contamination although we also regularly clean our MAF sensors. A more probable cause could be the poorly designed and mounted air intake tube and MAF sensor mount as we used a K&N cone filter for this unit.
Another thought is possibly some put too much oil when they "recharge" the filter?
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
