Page 41 of 134 FirstFirst ... 313738394041424344455191 ... LastLast
Results 801 to 820 of 2668
    Apr 2010
    #801
    Quote Originally Posted by Epats View Post
    Share ko lang. Naglagay ako ng full tank Petron Blaze. Mausok naman. and sobra amoy ng usok. Has anybody here experienced the same?
    sorry sir, haven't used petron blaze as of now.. wala din akong nabasa from other forums regarding blaze and the suzuki APV.
    I always use shell premium, dati unleaded..
    Oct 2008
    #802
    Quote Originally Posted by olidotcom View Post
    gumamit ako dati ng "super premium" sa shell, and a day after napansin ko mausok at masakit sa ilong ang ibinubuga ng tambutso (kapag nalalanghap), so ang ginawa ko binalik k na lang ulit sa "super unleaded".. tapos nawala na yung usok at yung amoy na masakit sa ilong..
    binasa ko ang manual ng suzuki apv natin, at nakalagay dun ay unleaded gasoline lang dapat gamitin.. dahil unleaded engine ang suzuki apv natin, otherwise maaring masira ang makina natin kapag patuloy natin ginagamit o gagamitin ang premium gasoline..
    #803
    add-ons pa...
    since nag add ako ng subs, my stock headunit jumps the current playing CD.. so nakaka bwiset siya.. talon ng talon yung music ko
    I took chance to buy a FM modulator from CDR-king for 550 pesos knowing that there could be a huge chance of static noise while playing music.. luckily wala! yeaaaah!
    temporary install ng amp ko sa likod ng driver's seat...
    Hi Sir! Nice set-up. Balak ko din po na mag-audio set-up with my APV since may problem yung head unit ko. I'm not sure kung stock ito from Suzuki, but it has a CD/USB and SD reader kaya lang hindi na gumagana lahat since last month. Bumili ako ng FM modulator (just like yours) to be able to play SD and USB but yesterday, even the FM is no longer functioning. Patulong naman po, if you know how to remove the head unit in an APV. Thanks in advance!
    Oct 2008
    #804
    Quote Originally Posted by rigelmar View Post
    simple... just go to your near car audio shop/store and ask them if they can remove your car stereo and of course you have to pay for the labor... or you can do it yourself (DIY) by pulling it out w/your both hands and fingers, you better have a good grip for you to do that..
    #805
    Hi, anybody naka-experience ng "engine trouble lamp" alarm? umilaw kasi yung sa akin and so far wala naman akong makitang effect sa performance. APV a/t yung kotse ko. kung na-experience niyo to pa-share naman paano niyo naayos.
    thanks.
    Sep 2010
    #806
    Quote Originally Posted by raffy9194 View Post
    i suggest u put the a/c sa 2 or 3, pag malamig na ,saka mo hinaan.d advisable palagay aircon sa likod.
    Sir Raffy, bago lang po dito and currently might close a transaction to buy an APV GA... Patanong lang bakit di advisable ang aircon sa likod?
    Sep 2010
    #807
    share ko lang... my APV.. proud owner lang po..
    Sir Olidotcom, ask ko lang din ikaw if may rear aircon ang APV GA mo? Di ba mainit pag walang rear AC? Bago lang po dito and might close a transaction to buy an APV GA these next few days... Thanks a lot..!
    Apr 2010
    #808
    hi sir Mat, meron pong rear aircon yung GA ko. sa philair kami nagpalagay.. malamig na malamig siya.. 1 year 3 months na po siya. no maintenance pa as of now. daily drive.
    May 2008
    #809
    Tanong ko lang po kung CBU saan etong APV type II. Balak naming bumili kase. TIa
    Sep 2010
    #810
    Hello Sir Oli, thanks sa reply mo... Just got my APV-GA last night, medyo hassle lang, di nilagay agad ng dealer ang mga pinadagdag kong alarm kaya inabot kami ng gabi sa releasing lang... Anyway, tama pala na yong may rear aircon na din ang kinuha ko... Philair din siya, 30K ang charge ng dealer pero pinababa ko sa 25K... Nag try din ako direct sa Philair, kaso 30K daw tapos 4 days to install, so mas mura sa dealer...
    Apr 2010
    #811
    good deal yan sir... sakin 30k bayad.. good discount na din.
    congratulations on your new APV! kita kits sa GEB
    #812
    To Sir Oli and others na may rear aircon sa APV nila,
    Pansin nyo ba kung nagmo-moist yung roof nung apv nyo? Ganun kasi observation ko sa akin (type II GLX) and concerned ako na maapektuhan yung rust proofing. Normal kaya yun?
    TIA,
    Jun 2010
    #813
    Quote Originally Posted by carchase View Post
    India yata.
    Apr 2010
    #814
    Quote Originally Posted by teteng View Post
    TIA,
    naku! sorry po, haven't known that issue.. but thanks for the information, ill try to check that out later pag uwi ko from work if nag mo-moist siya...
    regarding rust, i doubt naman.. i saw other vehicles that have moist on their rear panels / fenders due to aircon... and medjo 3 to 4 years old na sila.. no sign of rust naman..
    but just to make sure.. ill check and reasearch on this one as well..
    #815
    possible side effect pag nag moist yung roof liner ng sasakyan - posibleng bumaho yung interior kasi basa / tuyo na cycle nung insulation tapos kulob pa.....posible din yung rust from the inside out because nung exposure sa moisture....
    just take a look at most vehicles, bihira tamaan ng kalawang yung engine bay because of the heat...wheras madaling mabulok yung likod na tambol and trunk because walang heat doon to vaporize the water....(well, aside from the portion na dinadaanan ng exhaust)...
    #816
    Quote Originally Posted by totie_phoyah View Post
    Sir Totie ask ko lang kung nag lagay ka ng Super Premium sa APV mo, nag bago ba yun takbo ng sasakyan mo? yun Premium, alam ko Unleaded na siya, di leaded. Sa palagay ko lang, kung parati mag hahalo ang gasolina, baka masira. Kung once lang ok lang. And ask ko lang kung ano ang octane rating ng APV mo na required na naka lagay sa Owner's manual mo, kung 91 octane or higher? Kasi kung 91 (93 octane sa ibang cars), meaning pwede unleade or premium. I don't have an APV planning to get palang nabasa ko itong thread na ito. Very interesting. Thanks and more power.
    Pahabol sir baka shell lang ang premium na masakit sa ilong. Di tulad ng caltex Gold at Petron XCS di masakit sa ilong. It depends naman siguro sa sasakyan.
    Apr 2010
    #817
    Quote Originally Posted by drich_enriquez View Post
    sorry medjo out of topic..
    regarding gasoline, may nabasa ako mga sir.. mga gasoline products daw po natin is really.. without lead content na.
    but the difference between premium and unleaded 'daw' us that premium has a 'lead-substitute'. parang lead? but not lead? ahihihihi!
    going back to topic, im using shell premium and at the same time observing din kung magiging mausok din katulad kay sir totie, no smoke naman po sakin.. but if it goes out.. balik unleaded agad ako.. ahihihihi!
    na observe ko lang kasi, switching to premium gave more power sa engine ko, and slightly lower fuel consumption, so positive effect. lapit na din change oil ko this october or early november.. ill have my engine checked for any ill-effects using premium.. pray ko sana wala...
    Apr 2010
    #818
    Quote Originally Posted by nameless411 View Post
    nine-nerbiyos agad ako dito ah.. need to check if there is moist sakin...
    #819
    Thanks for the info Sir Oli. Palagay ko walang effects sa makina mo uising premium. Ask ko lang kung ilan kmh/p sa highway consumption using Premium sa APV mo? or nasa city driving ka lang?
    Apr 2010
    #820
    Hi Sir Drich,
    both city and highway as daily drive. to be specific, from Paranaque -> Mia -> Domestic -> Resort World -> SSHiway -> Right at Dela Rosa -> Makati Med -> Ayala -> Edsa -> Kalayaan Ave to Global City.
    pag pabalik na route.. i take makati->edsa thru magallanes-> domestic airport -> to paranaque sucat.
    Rough estimate of 9 to 11km/liter FC ko.
    I have an old GA style instrument panel, if pareho po tayo (not sure) there is a 1/4 triangle mark sa gasoline meter.. if i reach the top of that.. i already travelled around 100 kilometers.. upon reaching half tank.. around 200 kilometers travelled.
Suzuki APV [Merged Threads]
