Results 2,561 to 2,570 of 2668
- Jan 2019
- 36
February 7th, 2019 06:54 PM #2561Anybody knows how many km can a Suzuki APV (manual) still travel when fuel meter is at "E" ? For example, mine here "Fuel meter near E photo" i decided to gas. But I am curious, just how far can it still go if at "E".
my apv gas chronology
Thanks.
- Jul 2011
- 81
February 12th, 2019 04:50 PM #2562
- Jul 2011
- 81
March 8th, 2019 12:51 PM #2563Good day peeps,
Meron ba aftermarket brake shoe set tulad ng bendix for our apv? How much kaya mine is in need for replacement?
- Apr 2019
- 58
April 30th, 2019 09:45 PM #2564My technique is to release the clutch a little until you feel that it has already engaged like a half-release just enough not to stall then your right foot from the brake pedal shifts to the gas pedal and make adjustments to the clutch. This would limit the backing up of the vehicle.
- Jun 2017
- 19
May 1st, 2019 04:09 PM #2565
- 54,228
May 1st, 2019 04:12 PM #2566might i inquire,
is this based on someone's experience, or on published literature?
sa non-suzuki ko kasi, at "E", i still can do at least 20 km, based on ill-advised experience.
but i did lose once on the empty tank roulette.
i forgot that we had moved the fuel tank earlier, and had not re-calibrated it afterward.
buti na lang, the gas station was just a hundred meters away...
but we did have to scrounge around, for a suitable fuel container.Last edited by dr. d; May 1st, 2019 at 04:25 PM.
- Jun 2017
- 19
May 1st, 2019 04:33 PM #2567To share . . . I drove the Tagaytay-Talisay zigzag road, from Batangas to Tagaytay this holy week (some labelled this a 'dangerous road') in my APV SGX 2012, 6 adult passengers including myself, 9pm. I made it! Have to used L gear on very steep climbs, almost a U curve. The APV was reving at 4000 rpm, but it was able to climb. Good experience but scary!
Sent from my SM-G925F using Tapatalk
- Jun 2017
- 19
May 1st, 2019 04:37 PM #2568
- Jan 2019
- 36
June 9th, 2019 06:53 PM #2569Suzuki APV GA manual daily commute Cebu City fuel consumption report updated regularly:
apv_gas_odo.txt - Google Drive
- Jan 2019
- 36
June 9th, 2019 07:39 PM #2570If the road is an uphill climb, the gas task is in an uphill position. Does this have an effect on the remaining fuel liters inside the gas task? The effect i'm thinking could be one of the following:
- it decreases the usable gas to do the drive
- it increases the usable gas to do the drive
- no effect at all.
Thanks.
Best bet is along the Rizal Memorial Sports Complex across the site where HP used to be. Yun nga...
Recommended Parking Near De La Salle (Taft)
