Page 145 of 267 FirstFirst ... 4595135141142143144145146147148149155195245 ... LastLast
Results 1,441 to 1,450 of 2668
    #1441
    Quote Originally Posted by keno4864 View Post
    Just an update, I was able to go 80 kph and above this Sunday with my apv.
    I can begin to notice the humming or whining (umu-ugong) sound starting at
    40 to 50 kph up to 70 kph ( not that loud as before ) and then disappearing
    at 80 kph and above. Don't know why? Maybe, there are minor wears already
    in the pinion and ring gear? Or not properly mesh gears? Need to observe it
    further for now and I hope it's not from the automatic transmission anymore.
    *Keno4864 sir, did your mechanic tried checking propeller shaft and ujoints?
    I asked if the cross joint in the propeller has damage and they reply no because they check it when pulled
    down the propeller to remove the pinion's bearing. I also asked how did they measure the clearance between
    the pinion and ring gear? They said they used a filler gauge. Maybe, they might have set the backlash
    incorrectly? Or there were minor wears already? I red that one of the critical measurements that must
    be made is setting the backlash. What is backlash? When I turn the pinion on the differential it will
    turn a specific amount of space before it actually contacts the the ring gear to turn the axles. If I have
    too little backlash the pinion is jammed into the ring gear and this will produce a lot of friction and heat
    and will lock up the rear axle. It will not turn freely. If I have too much backlash the pinion and ring
    gear will be too far apart and this will allow the gears not to mess properly and with the force of the motor,
    it will chip and destroy the teeth of the gears. This will cause excessive whining and will eventually destroy
    the axle. Maybe the gears have this damages already?
    I called up Suzuki parts today and inquire about the rear differential carrier sub assembly ( bungo yata
    sa tagalog ) and it cost 125,921.00 Php ! They say, the carrier assembly is hard to fix because the gears
    inside has specific clearances. If I buy the part they will just install it to the differential housing and it
    already includes the pinion and ring gear. The question now is, how accurate can they set the clearance
    between the pinion and ring gear?
    Anyway, I will just keep on using the apv and hopes it does not get worse. Thank you.
    Jan 2011
    #1442
    *keno and oli - thanks mga sir. dito kasi sa baguio wala naman nagsisita.
    gusto ko lang malaman kung paano patakaran diyan sa lugar ninyo. gusto
    ko sana palitan ng yellow yung fogs pero karamihan naman kasi dito
    puro puti ang foglights. siguro para makaiwas sila sa sita. marami dito
    naka on palagi ang foglights.
    #1443
    * Keno, sir baka meron sa salvage yard..hehe. Backlash, in tagalog salyada.. It wont cause much vibrations but yeah gears will get damaged later if not within correct specs. Noise and sound troubleshooting can sometimes be a biatch, that isolation by elimination method is the only solution.
    IIRC, youre AT pan had a damage/dent, its also probable that the propeller was damaged causing sound/vibration/oscillation on a certain speed.
    Try also the runout procedure maybe some shop is offering the service similar to this..
    Or if it wont cause you toomuch worries and you could tolerate the noise, just ignore it..hehe
    Dec 2012
    #1444
    mga boss. ask ko lng kng ok ung kulay na ibibigay sakin na tint. Platinum ung brand and Dark20. un daw standard ng apv. d b masyadong madilim un? tnx
    Apr 2010
    #1445
    Quote Originally Posted by danding View Post
    ay sir.. nasa baguio nga pala kayo.. you dont have any worries on those.. required nga dapat kayo naka fogs dahil nga foggy dyan sa baguio.. and yellow fogs is also proper.. mas kita kita lalu na kung malakas ang ulan.
    Jan 2011
    #1446
    Quote Originally Posted by olidotcom View Post
    oo sir required dito kaya lang kung minsan mayabang mga driver ng mga jeep dito lalo na yung
    mga bata na hindi taga baguio. minsan nga muntik akong banggain ng isang jeep dahil nasilaw
    ata sa headlight ko eh naka low beam naman ako at trapik (nung naka corolla pa lang ako
    kaya ngayon sa apv ko naka off palagi tong fogs ko. hays buhay nga naman.....
    #1447
    Try also the runout procedure maybe some shop is offering the service.
    Thank you 12vdc, I will try to ask around if this rear differential gear assembly is available in the salvage
    yard or as a surplus parts but I know it won't be easy to find one. Suzuki parts also have to order this
    carrier sub assembly in Japan and will take about 45 days according to them. Price is 125,921.00 Php !
    The shop told me to bring the apv back to them after one month to check if they need to re-adjust
    the pinion and ring gear. I feel that the shop may have adjusted the pinion and ring gear a little tight?
    It's hard to find an auto repair shop or machine shop that specialize in fixing the differential or propeller
    shaft here. The auto shop here can replace all the bearings in the differential assembly but I am not
    sure they have the instrument and experience to accurately return it to specs.
    Since I use the apv everyday to take the kids to school and only run four kilometers a day with
    speed below 40 kph. The noise or sound is hardly noticed.
    I red this in the web and I think this might be the problem in my apv's differential.
    From : VehiCROSS.info Forums > VehiCROSS Topics > VX Troubleshooting... > Differential whine fixed!
    Post by : PBR , 10/05/2003, 06:10 PM
    " It was a high pitched whine foot on the accelerator, no noise foot off, dealer put new gear and bearings in diff. problem solved. "
    Differential whine fixed! [Text View] - VehiCROSS.info Forums
    Suzuki apv automatic transmission humming sound - YouTube
    If this is the problem, the pinion and ring gear can be ordered at Suzuki parts and will cost about
    37,382.00 Php. They say it would take three days to order the parts.
    Anyway, I am still observing the sound and just enjoy driving the apv at the moment.
    Happy weekend to everybody, thank you.
    Dec 2012
    #1448
    hi po mga boss. nakuha ko na ung apv ko last friday. break in ko agad sa highest point. then baba kamu manaoag for the blessing. ok talaga cya tumakbo parang kotse lng. d hirap sa curve and akyatin. then ung topspeed n napaabot ko sa kanya is 145kph. tingin ko kaya pa tumaas. 800 kilometers ung inabot ng trip namin and we only spend a full tank and a half. papa change oil ko na kaagad sa saturday. just sharing po
    Jan 2011
    #1449
    Quote Originally Posted by miletpogi View Post
    ayos sir miletpogi!!! congrats sa new ride mo. enjoy your ride sir.....
    Apr 2010
    #1450
    upcoming Team APV road trip to Lipa Batangas mga sir! hope you can join this December 22!
Suzuki APV [Merged Threads]
