View Poll Results: What is your tire pressure? (front tires if front & rear tires aren't the same)
Voters
288. You may not vote on this poll
  • 24 & less psi
    2 0.69%
  • 25-26 psi
    3 1.04%
  • 27-28 psi
    15 5.21%
  • 29-30 psi
    110 38.19%
  • 31-32 psi
    88 30.56%
  • 33-34 psi
    24 8.33%
  • 35-36 psi
    31 10.76%
  • 37-38 psi
    6 2.08%
  • 39-40 psi
    7 2.43%
  • 41 & up psi
    2 0.69%
Page 5 of 8 FirstFirst 12345678 LastLast
Results 81 to 100 of 209
    Aug 2005
    My figures:
    Vehicle: Toyota Innova
    Tire size: 205/65R15
    Tire brand: Yokohama Aspec
    Front pressure: 33 psi (loaded/unloaded)
    Rear pressure: 33 psi (unloaded)
    Rear pressure: 36 psi (loaded)
    Note: Tire pressure figures on cold temperature recommended as per manual.
    Sep 2004
    front -> 30psi
    rear -> 32psi
    that's what my car manual (mazda familia) recommends for 195/55/15 spec tires. since those are my tire spec, i just followed :D
    Aug 2004
    Digitals will never be as accurate as analogue, but considering our analogue gauges here are 100 pesos pieces of crap, yes, it's relatively accurate. The digital gauges at shell always give me consistent readings... that's when the tire pumps are working.
    30-30 di ko naman load ng mabigat rav4
    Aug 2005
    I own 3 types of gauges, 1 made in Japan in which a graduated rod comes out after detecting a pressure (maybe familiar to you as this is usually used in vulcanizing shops). My 2nd gauge (analogue type) made in Taiwan. My 3rd gauge (also an analogue type) made in Italy a type in which you can monitor tire pressure from a dial attached to a nozzle. Pulling the trigger inflates, pushing a release button deflates. This type is widely used in auto dealer service bays. Having these three types has no way for me to have inaccurate tire pressure. Well, of course, tires pressures are accurately obtained in the morning while air temperature is still cold. Tire pressure obtained during hot weather temperature are erratic due to air expansion.
    Dec 2004
    Quote Originally Posted by leinahtan
    What? Hot weather will not give you erratic readings! Assuming temperature remains constant, your readings will remain constant. I believe there is a misunderstanding of some basic laws of physics here.
    Everything else remaining the same, when temperature rises, so does the pressure of gas. But that doesn't mean taking tire pressures at higher temperatures will result in erratic readings!
    Pressure readings should be taken when the tires (not the air) are cold, that is, left standing still after a few hours of driving. The normal driving tire temperatures are significantly higher than your parking temperatures.
    May 2004
    190 e with 215/40/17= 30 all around
    '96 Surf/4runner with 215/70/16= 35 fronts, 40 rears
    eversince i bring our cars to our friendly shell gas station and have the tire pressure checked there. 30 psi for our cars and 35 psi for our van. then i give 5 pesos to the attendant.
    32 para safe, & dapat magdala ng sariling gauge...how many times kyo chek ng tire pressure? weekly b? npansin ko pag after every 2 weeks mdyo marami na nababwas...
    Dec 2004
    questions:
    1. san po ba nakakabili ng high quality gauges?
    2. ok lang ba hindi mag tip sa mga gas boys after magpahangin? :D
    32-33psi cold on all fours- sedan
    35psi cold on all fours - Frontier
    It is recommended to buy a good tire gauge, the thing is i don't know what brand to buy and where (any recommendations?).
    Dec 2003
    32 psi on 4 tires
    Bridgestone H/T 255/70/16
    nangkang 265/60 18
    32 on all 4 cold ones
    spare should be 5-10lbs higher kasi we often forget to inflate them
    Jul 2003
    i use 32 psi on all 4 tires for my L300 Van, ok lang ba to.
    kasi yung nakalagay sa door niya is 35psi, pero kung 35psi parang matagtag ang riding. any comments.
    Apr 2005
    honda city 27/27 psi- loaded with nitrogen air when I changed tire early this month. good handling experience.
    mits adv 27/37 psi - normal air
    Dec 2003
    Gen1 CRV - 28psi all around 205/70r15 stock tires, 32 psi for the 245/50r18 rims
    E36 320i - 30psi all around, 205/40r17
    30 on all tires. tapos mga 2x a week, saka basta pag dumadaan ako sa shell lagi ko na rin chinecheck.
    ok lang ba ung every other day na check ng pressure? o masyado ng overkill?
    salamat
    Sep 2005
    32 psi all around, 215/40/17 tires :D
    Sep 2002
    pressure recommended on door is 33/33 for 215/65/15.
    how would this translate to 225/65/16 tires?
    am currently running 30 psi. is this about right?
    Aug 2004
    Should be the same. But why are they so much bigger? Don't they rub? Or is it an SUV?
Your Tire Pressure
