Results 61 to 70 of 93
- Sep 2016
- 2,280
June 16th, 2022 12:30 PM #61
June 16th, 2022 04:15 PM #62
^ naks! voice assisted pala ang tpms mo. Iyong akin hanggang beep lang [emoji16]
Pero yeah, tempting nga hindi na ilagay iyong lock nut kaya iyong akin hindi ko na tighten masyado iyong nut at iyong sensor. Ako Lang naman din kasi top-up ng air every now and then.
Come to think of it, Sa more than 5 years ko gumagamit nitong external tpms, wala naman atang nagka-interest sa sensors ko. Hindi naman din kasi siya eye catching even for a naughty kid - i'm guessing. Pero sabi nga nila, "never say never".
- Sep 2016
- 2,280
June 16th, 2022 05:11 PM #63
June 17th, 2022 07:47 AM #64
- Sep 2016
- 2,280
June 17th, 2022 04:39 PM #65Ganito yung gamit kong TPMS.
Sa baba nung tire pressure, dun lalabas kung no signal, may leak, high temp, low batt, etc. at magkukulay red yung broken lines na nakapalibot sa circle.
Yung sensor walang pinagkaiba dun sa external na solar yung monitor. Ang bluetooth receiver nya is kamukha ng GPS module ng aftermarket head units.
June 20th, 2022 11:12 AM #66
bro may link ka nung product?
Sent from my DN2103 using Tsikot Forums mobile app
- Sep 2016
- 2,280
June 20th, 2022 02:57 PM #67Ezonetronics Universal Spare Tyre External Sensor External USB TPMS for Android Headunit Tire Pressure Sensor | Lazada PH
Dito ko nabili yung akin. Nagcheck ako sa shopee ngayon at marami na rin dun. Nung bumili kasi ako noon, kaunti pa lang sa shopee eh. At mas mahal pa benta.
June 20th, 2022 03:54 PM #68
sana gumana yung app sa "ibang" model ng tpms ko
mukhang mas ok yan app mo e
June 21st, 2022 03:11 PM #69
So decided to push through with my plan to install an external TPMS with solar charging like the following.
Easy peasy installation. After fully charging the base unit, I installed the sensors in order - LF> RF> LR > RR.
The rear sensor readings are quite accurate. I have the rears inflated to 32psi and sensors read 31~32 psi.
Problem is with the front sensor readings. I have them at 36psi and both are off by 2~3psi.
Temperature reading for the LF is also off. All the sensors are reading 24~28° while LF is at 30~33°C.
I tried swapping sensors at yung rear sensors do read the fronts correctly at 36psi.
Bought mine sa Shopee at around ~600.00 only baka kaya may "factory defect".
Other buyers kasi seems to not have this problem.
Well, it could have been good as indicators na lang and not one with accurate readouts.
Para lang alam mo na hindi pa naman flat or sumabog na pala ang gulong mo.
If that happens at least may mag-aalarm to warn you of said catastrophic event.
My main concern right now though is yung mga sensor mismo or their effect on the rubber stems.
May nabasa ako na napunit yung rubber ng valve stem or pito due to the sensor weight.
Kung within dito sa barangay lang namin or running 80kph max baka di pa naman critical.
Pero kung running at highway speeds at 100~140kph baka cause for concern na.
Kaya baka I might switch na lang din sa Android based TPMS with internal sensors.
I went with the external one mostly due to the convenience, not having considered the safety issues.
Also, I didn't realize how relatively easy lang din pala ikabit yung internal sensors.
Of course, you might have to do it via a tire shop to properly fit them, albeit with minimal cost I guess.
Found one at Lazada na mas mahal lang ng kaunti sa mga external TPMS at Android TV based na siya.Last edited by gearhead000; June 21st, 2022 at 03:13 PM.
- Jun 2015
- 2,751
June 22nd, 2022 07:15 PM #70My main concern right now though is yung mga sensor mismo or their effect on the rubber stems.
Social media made y'all way too comfortable with disrespecting people and not getting punched in the face for it. - Mike Tyson
Xiaomi E-Car
