For over 40 years of experience as a Tech and thirty years as an instructor, I have never seen wheel alignment specs with the driver on board. The specs may vary depending on which side of the road it is to be driven. Adjustments are made using curb weight(with a tankful of fuel). If the fuel tank is less than full, you compensate by adding a corresponding weight where the fuel tank is located(around 6 pounds of gasoline per gallon.
From what I have seen, some premium/performance makes, like BMW, suggest weights(sand bags) on driver, passenger, trunk aside from having the fuel tank full. Hunter & Hofmann do follow them. This is to simulate their independent suspension's angles not just when the vehicle is loaded but also when it's driven at high speeds.
