Yes, they will first check that your suspension is healthy. If not, they will not perform the alignment. That's SOP.
But they're good. Bridgestone Tire Center on Pasong Tamo is also good alternative.![]()
Thanks SA maliwanag na sagot...
Pudpod kasi gulong ko SA harap naka negative na Yung gulong NG car na di masyadong ginagamit dito balak ko ipaayos, pinagawa ko na tie rod nun then Sabi ni mekaniko sur basag na wheel hub bearing.
naalala ko Lang balak ko kasi icamber alignment next week.
when your vehicle has handling concerns, first you have your suspension checked for worn out, failed parts (analyze the cause of the part failure)
then have a prealignment check:
tire age, pressure, size and condition
ride height
wheelbase measured (both sides)
place the vehicle at curb weight (compensate lost fuel by adding a commensurate weight- 6 pounds per gallon)
then do the alignment routine:
rear camber
rear toe
thrust angle
front camber
caster
kingpin inclination
toe out on turns
front toe
over center adjustment
front wheel setback
steering angle sensor reset if applicable
anything less is just pretend and incomplete wheel alignment
^ pang formula 1 yatang alignment Yan mga sur [emoji1]
Ginagamit ko Lang pra bumili ng pandesal car naming extra kya ok na yung simpleng alignment Lang pambawas pudpod SA gulong
Yup, ang OA naman kasi eh. Extreme masyaso. “Pretend wheel alignment” na agad without regard to whether or not a lesser procedure is sufficient na for the 95% of the vehicles in the PH.
Tapos ang kicker, wala naman pala dito sa PH ganyang service.
Yes, Disneyland is definitely better than Enchanted Kingdom, but it’s irrelevant kung ang scope ng question only covers the best theme park in the PH.
ano ibig sabihin nun after adjustment sa front, di nila kaya gawin 0° perfect yun?
thanks!
nakapunta nako shell c5 near mitsubishi ..
gamit nila the hunter pa100 PA 130
yun na ba yung ok na klase?
550 alignment nila
camber 1.6k (iirc)
Nasa acceptable range na.. di naman talaga ma perpek yan kasi may error din talaga sa rim imperfections, machine calibration etc...
Sakin dapat yung 3d alignment machine talaga gamit at may specific car model na installed dun sa machine.. madalas ngayon hunter na gamit or yung john bean
Camber at wheel alignment sa area namin P1200, di Naman apektado if after NG alignment ako magpalit NG bagong gulong Noh....?
