Results 1 to 2 of 2
Tsikot Member Rank 4
- 1,842
February 6th, 2003 12:08 AM #1Nagkaroon ng lukot sidewall ko nung tinakbo ko ng 28psi
sabi dapat 30psi daw pero bagsak pa din
ok lang ba 33psi?
gulong ko
UNIROYAL
Rainsport 1
195/45/r14
February 23rd, 2003 11:23 AM #2
Check what's teh max pressure rating for the tire and you're safe in any pressure setting below it. You can safely go to 35psi IMO (we do that with our cars sometimes).
Try experimenting with the variuos psi set-ups until you get what you feel is the best compromise between performance and comfort. On our cars, i usually run 31-33psi (not much tire squeal during cornering and better road feel).
Running on a higher psi rating for your 45series tires will also help protect your rims from damagae or "bingkong" a little more and also improve your fuel mileage a bit.
HTH.
^ serpentine belt Pala nagpapa-work Ng water pump sa k20 engine. Salamat Naman at ayuz pa...
waterpump area may konting leak
