Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
    Apr 2009
    #21
    Quote Originally Posted by cjtjamandra View Post
    ano pa kaya ang iba pang reason? help po...
    Yung sakin nagvvibrate kasi unevenly worn na yung tires.
    Nung napalitan, ok na!
    Kaso ngayon meron na naman kasi nalubak ako lately at nabasag yung mags ko.
    May tama hanggang velocity joints.
    #22
    Quote Originally Posted by isa1023 View Post
    ano pala scientific or logical reason bakit nag vivibrate on 80++ kph if unevenly worn yung tire? sorry newbie kasi eh.
    iba kasi vibrate nung akin, parang dumadaan ako sa stopper.
    #23
    mga bro anong magandang brand ng rotor disc for civic lxi?
    nagtanong kasi ako sa servitek kung magkano pa reface bale 1250 per wheel.. halos kapresyo na ng replacement rotor disc..
    ok ba yung replacement lang? or pareface ko na lang?
    tsaka ilang disc po ba meron per wheel?
    Dec 2010
    #24
    Well you know, all rotating parts in a car are subject to vibrations. Brake drums, propeller shafts, flywheels and engine crankshafts are all balanced to counter the vibrations.
    Old, worn-out tires may have uneven patches and bulges enough to vibrate even at moderate speeds, and if the belts are separated already. Or still possible, the old tires on their rims were just out of balance and when you replace it with new ones, the tech balanced the wheel and eliminated the wiggle. Remember that as the tires wear out say in a few months, the state of balance changes so you have to do it again.
    To use an analogy, an old electric fan with bad rotors will shake slowly in the first setting, then vibrate wildly in 2nd, and will be steady at 3rd or maximum setting because the speed compensated for the imbalance.
    #25
    Quote Originally Posted by ericbalajadia View Post
    ok boss naintindihan ko na. pero yung sa akin hindi naman nag vivibrate kahit 100kph++, lumalabas lang yung vibration if nagbbrake ako.
    Nov 2007
    #26
    As i've said, the culprit could be the rotor disc. Honda Lxi has 2 front wheel disc brakes, 2 wheel rear drum brakes. If i remember it right, meron sa mga servitek nag rereface ng rotors, around 750 per disc yata.
    #27
    Quote Originally Posted by Howard Roark View Post
    naginquire ako sa servitek richwell.. 1350 per disc daw ang pa reface.. kapresyo na ng replacement part which is 1,100
    ok ba bro quality nung replacement lang?
    #28
    most likely tama si howard kasi ganyan na ganyan ang nangyari sa crv ng friend ko basta pag nagbrake ka lang nagbavibrate warped rotor yan, kasi kung yung mga parts ng suspension ang sira minsan di ka pa nagbrake ramdam mo na saka di specifically vibration ang symptoms.
vibrate when braking
