how muxh would it cost?
another question!!!
my van has 4 studs para sa rims......ano ang term para dun sa distance ng studs para kumasya ang mags? i tried placing a 15" toms mags, pero hindi siya kasya dun sa studs.....may slight difference siya.....pang corolla lang pala yun.......hindi ba standard ang sizes nun basta 4 holes yung mags? I am confused......:D
boss n3il53n, i also have a liteace, pcd 100 po ang corolla, ang liteace naman po is pcd 114.3, di po kakasya yung toms na pang-corolla, unless pcd 114.3 din po siya. btw, pcd means pitch circle diameter.
p.s. dugtungan ko lang yung sig niyo...
y'all goin' make me lose my mind, up in here, up in here.
y'all goin' make me go all out, up in here, up in here.
y'all goin' make me act a fool, up in here, up in here.
y'all goin' make me lose my cool, up in here, up in here.
thanks so much for the info jimbob.....teka.......nasa KAC ka din diba? nagpalit ka na din ba ng mags ng liteace mo? san ka nagpakabit? sawa na kasi ako sa stock mags ko eh.......pwede ba akong gumamit nung sinasabi nilang universal na mags?
as for the p.s. .......mahilig ka rin pala kay DMX.......:D
di pa ako uma-attend ng eb dahil wala pa po akong system. nakow, luma na po ang mags ko, 15x6.5 po siya with 195/60/15 falken ziex ze-502. i have that set of wheels since we bought our gxl in 1995. very satisfied naman ako dahil nag-iba talaga ang handling characteristics niya. sa banawe po ako nagpakabit and maghanap lang po kayo sa banawe, maraming styles po ang kasya sa ride natin depende na lang po style na gusto niyo. about the tires, buy falkens, take my word for it.
I plan to replace my tires with 205/50/13......and my friend told me that maganda daw gamitin ang "american racing wheels" na mags.......would you guys recommend this? how much would this cost for a 13" mags that will fit my desired tires? thanx in advance...:D
neilsen, medyo maliit yung tire combo na gusto mo, 2 inches sng discrepancy ng stock tire and ng combo na gusto mo, medyo apektado ang fuel mileage, ride, ride height and final ratio mo. you'd be better of with a 14 or 15 inch wheels.
A friend of mine had a set of American Racing wheels for his USDM Civic. He says the wheels were pretty decent, and were much better (lighter and more aesthetically pleasing) than the stock steel wheels that came originally with the car (the ugly bottlecap wheels with the plastic wheel covers).Originally Posted by N3IL53N
He had them for 4 months and they were pretty durable, having survived multiple encounters with potholes the size of moon craters. He sold his car (after 4 months after he switched wheels) and the aftermarket wheels helped inflate the car's price by a few hundred $$$.
It's worth giving it a shot, if you do get a good deal on them!
so using 14 to 15" mags will be better.......how does it affect fuel mileage and final ratio......?
mahihirapan tumakbo ang van mo, i have had 195/50/15's nung bago pa yung van, medyo maganda ang arangkada, pero sa rekta, iwan ka na, if you desire to cruise at a certain speed (e.g. 100kph) the tendency is to overrev the engine, than cruising with stock or close to stock specs ng tire. this is from my experience, kaya nung mag-60 series ako, very effortless na ang cruising, i guess i gave the engine a break.the practical sizes would be from 13-15 inches. but you can go as far as 16-17 if you desire. huwag ka lang lalayo doon sa height ng stock tires which is 23 inches, as it will definitely give you problems, it will just be a matter time.
kasi napansin ko din na pag tumatakbo ako ng 120 (limit speed ng van ko) parang over rev na......what if I use 195/60/13 or 195/50/13 alin sa dalawa ang mas maganda? suggest ka naman po ng best spacs for my wheels..........:D
Neilsen,
What's your stock tire size again? Are you now open to changing the tires?
N3IL53N,
check this out:
http://miata.net/garage/tirecalc.html
maybe this will help you decide the proper plus size tire you're going to get.![]()
IMm29 am currently using 185/60/13 tires by bridgestone....bison.....light truck...8 ply.....
pierre nice site......ang lakas pala makatipid ang larger wheels.....:D
Neilsen,
you might wanna try upgrading to 14s, so you have more choices as to wheel designs and tires. 14s aren't much heavier than 13s, so you don't sacrifice much in terms of fuel consumption and performance.
IMm29 I plan to go for the 15" mags.......thanks to pierre's suggested site......problem is......bibigat ang steering wheel ko malamang.......I plan to use
195-205/60/15.....halos 10% increase in speed and savings in fuel consumption and engine stress......what do you guys suggest.....:D thanx in advance.....:D
Neilsen,
I've gotten to do that upgrade on our AE92 Corollas before. Since they weren't power steering yet, talagang bumigat yung steering when parking or at a standstill. Kapag tumatakbo naman, IMO, mas ok coz since mas mabigat, mas less yung tendency mong mapihit ng biglaan. And steering is more precise with the bigger yet lower profile tire combo.
As to the way the bigger tires run, since they're bigger and heavier, accelerating/arangkada is slower. Parang di ka masyadong makausad. However, once you're up and running and just cruising, there's less stress on the engine to go at a higher speed. It's here, i would suppose, that you get much of your fuel savings.
Another point to consider is the tires fitting into your wheelwell without the sidewalls touching the fenders when you're running a packed van. This was a problem with the Corolla. Perhaps this won't be a problem with the LiteAce considering you've got more room for the tires and suspension to play.
In the long run, i think the additional unsprung weight of the upgraded wheel and tire combo will cause a little more stress on your suspension bushings, etc.
All in all, IMO, get the mags! :mrgreen:
another factory defect by Toyota.......bakit kaya ang liit ng stock tires ng liteace? pero ang wheelwell naman eh sobrang luwag.......I think kasya yung mags dun including a 195 or 205/60/15........napaka awkward tingnan kasi pag stock......you get the picture?......by the way.......saan ba magandang bumili ng mags na Rota? nakakita na kasi ako ng design sa internet......di ko lang alam ang location ng authorized dealers ng Rota dito.......any suggested shops?
