Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 50
    #31
    To be fair though, if I didn't tell them of my observations with the brakes, I'm sure they would've thought that the suspension was the culprit as well. Inexplain ko na kagad that I've changed all my suspension bits so they should look elsewhere.
    it really is of great help, bro, if the owner had the car sense kasi most mechanics defer to the owner or driver's diagnosis.
    May 2009
    #32
    and weld the brake pad edges as a solution.
    bakit hindi shims/anti-rattle clip brader?
    sabagay, cheaper na rin yung welding. i suppose. kaso iniisip ko lang yung adhesive sa brake lining baka nagbago ang ugali sa tindi ng init ng welding. or some other effects.
    Jan 2009
    #33
    Quote Originally Posted by miked View Post
    Oo, ang clip fills the gap/void between the brake pad & caliper bracket/support. Kapag wala ito at ang shim, may ingay na maririnig sa rough cement/asphalt road. Kadalasan, di ito naibabalik ng mga negligent na mekaniko kapag nagpapalit ng brake pads, & they usually say na, "okey lang 'yan kahit wala".
    #34
    i have a similar untraceable source of kalampag or knock too this time on our a/t 2.0 fd naman
    in my ride's case, the knocking sound makes itself be apparent whenever i'm maneuvering slowly (aka maniobra) at very slow speeds - usually when i'm positioning the car either to exit or enter a parking slot. sometimes the kalampag can also be heard when the car isn't moving pa while i'm directing the wheels to whichever direction i want the car to go. but when the car is already in motion - above say, 5 kph - the knocking noise is no longer there. like the ts, i've changed all sorts of suspension part bits already (both replacement and oem) and yet it's still there.
    btw, naka electronic power steering wheel iyong kotse at mukhang ok pa naman iyong system na iyon kasi wala naman check steering wheel light (not sure if it's called as such hehe) umiilaw sa cluster gauge
    so if you guys can give me an idea what the possible culprit is prior to visiting a suspension specialist that would be a big help.
    thanks!
    #35
    ^ up ko lang iyong tanong ko
    tnx!
    #36
    Hard to say but it could be your tie rod and ball joints. Baka kailangang i-repack?
    Jan 2016
    #37
    Parang CRUNK sound?
    Pacheck mo sir tie rod, rack end and ball joint
    #38
    Quote Originally Posted by TON_ton View Post
    Parang CRUNK sound?
    i already replaced my tie rods, rack ends, stab link, shock mounts, rubber stoppers, front shocks, and shock boots pero iyong ball joints ang hindi pa. will have them checked later
    thanks!
    Jan 2016
    #39
    thanks!
    Sure na ball joint yan sir [emoji106]
    #40
    thanks!
    san kuba nabasa, na itong kotseng ito, ay may kababalaghang engine mount..?
    that the engine mount sometimes wears out faster than industry standard..? and it makes a peculiar sound when it gets worn..?
Unknown Kalampag (Not Suspension-related)
