Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Jan 2003
    on all four tires maspudpod ang nasa outer thread ng tire.yung nasa loob makapal pa. what could be the cause of this? is it safe to flip the tire? backside will be the frontside na.
  2. #2
    You might need to check your wheel alignment.
    toe in ba ang term nila dito?
    naka-pike ang gulong.
    Jan 2003
    if its the toe in alignment. then bakit pati ang likod? is it ok to flip the tires?
    pwede din under-inflated lahat ng tires, so the tendency is the outer rim sags and gets worn out first. Kung toe in...sa harap lang dapat yung worn out pattern, malabo naman na pati yung rear tires naka toe in. best if you bring it to the nearest servitek.
    Sep 2004
    camber allignment lang yan pre
    basta suspension problem yan or incorrect tire pressure. most probably your front and rear camber needs to be checked and corrected. check your shocks if they are still performing well.
    Jan 2003
    I think I should also get my tires checked.Mejo madalas na kasi na mejo lumalambot ang tires. is it ok to flip the tires?
    to answer your question about flipping tires check first kung uni directional (performance tires usually are uni directional) ang tires mo. most tires especially passenger tires pwedeng iflip dahil bi-directional sila. pero kung performance tire yan i doubt kung pwede.
    Sep 2004
    in the case of underinflated or overinflated ang gulong, dapat nasa both outer thread ang pudpod and center thread pag overinflated.so definitely camber allignment and suspension check-up ang kailangan mo.but flipping the tires would be ur cheapest alternative.
    pwede yan bi directional ang tires mo, di ba pareho tayong naka bridgestone MT
    Jan 2003
    exactly. I'll flip the tires na lang muna. sana walang problema sa suspension. I was told before that upon lifting the tbars, the alignment can be a little hard to fix.
    malamang mayadong positive ang camber mo.
    Jan 2003
    tingin ko sa tbar crank..what doyou think?
    Quote Originally Posted by notEworthy27
    Common yan for IFS-torsion bars setups, lalo na pag wala sa camber alignment. Tuwing full turn mo medyo naka-hilig sa outer tread yung mga goma plus ito ang humihila ng buong front weight ng sasakyan.
    Pwede mong i-swap left-right & vice versa pero mas ramdam mo ang tread vibrations, kasi dun na umukit/nasanay ang upod ng goma. Mas maganda kung front-rear swap and hope na pumantay ang upod pag nilipat sa hulihan.
    Mar 2005
    Ano ba ang ride mo? Have it checked by experts and see kung ano ang sasabihin nila.
    Jan 2003
    Quote Originally Posted by Ungas
    I did swith the tire from front to rear. hmmm...parang kelangan na ng suspension lift... :D
    Mas lalong madali ang tread wear pag suspension lifted sabay di tama ang alignment.
    Oct 2004
    probably the camber is on negative (too much)... pa-check mo na rin yung toe and caster ng front...
    Jun 2005
    If only the outer treads are worn, this can very well mean too much POSITIVE camber on a MacPherson strut type suspension. Another reason for this is cornering too fast on double-A arms suspension with a weak anti-roll bar. (For some reason, McPherson struts aren't as much susceptible to this as are double-A arms suspensions.)
    Why the uneven wear pattern occurs on ALL 4 tires is because you "rotated" the tires front-to-back on the same side. What's likely happening is your front suspension has too much positive camber thus causing the uneven wear pattern, and switching tires on the same side merely exposed the previously unworn tires to the same stress, thus affecting all 4 tires.
    But if your car has 4-wheel independent suspension, it's also possible that all 4 corners have been wrongly cambered.
    Independent suspensions normally have a little bit of NEGATIVE camber dialed in to counter the tendency of the tires to lean together with the car during turns.
    To ease some of the confusion:
    Positive Camber = tires of the same axle are closer at the bottom (parang toe-in pababa)
    Negative Camber = tires of the same axle lean inwards at the top.
    Hope that helps.
uneven tire bite
