Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
    Jan 2008
    #21
    Quote Originally Posted by antontoni View Post
    I am also looking for an under chassis specialist or any shop na makakadiagnose ng problema sa accent (2013 crdi) ko. Went to 2 mechanics here in Laguna with no success. The car has a problem na kapag biglang bagsak at taas ng kalsada ay may tumutunog sa right part ng harap. Changed the bushings, coil spring, rack end, and ball joint and still no success. Been to two shops and they say wala naman daw problema I even asked if the shocks need replacement pero ok naman daw ang shock. So, I had to look for answers through the net and I stumble here. Baka may makakatulong sa akin? thanks.
    Check mo engine support
    May 2011
    #22
    Same problem ng Accent ko sir gas 2012 model. may tunog na langitngit kung biglaan bagsak or rampa. Pero kung normal na lubak lang wala naman. Naayos na ba yung auto mo sir at ano napalitan?
    May 2011
    #23
    Quote Originally Posted by jaynus View Post
    Naayos ba ito same issue sa akin accent 2012 ganyan din may langitngit pag biglaang bagsak
    Yun shock mounting na check na ba?
    Apr 2005
    #25
    Ang bilis gumawa sa Wheelers Banawe. I was second in line opening. Rear shocks replaced in 30 minutes. Paid 700 pesos.
    Mar 2021
    #26
    Wow, bilis at mura. Ikaw may dala ng shocks then labor lang sila?
    Jan 2008
    #27
    madali lang palit ng rear shocks lalo na kung nasa labas ng spring..
    Apr 2005
    #28
    Yes bro bought kyb online excel-g at 4.3k/pair.
    Sep 2021
    #29
    Sa Cavite kaya meron nito? Naghahanap ako ng specialist for custom suspension sana. Nag engine swap ako and parang hindi kaya ng stock suspension ung new engine. ang pangit ng ride quality.
    Apr 2005
    #30
    Went to Velocity Auto Underchassis Specialist yesterday kasi may rattle na ung rear shocks na pinakabit ko last May 2021. Leaking na pala.
    Changed both rear and front shock absorbers, bushings, dust cover, and mounting. Total cost was P23K. I was there 8AM and left at 10:30AM. Dumaan din sa Goodyear Ortigas Depot for wheel alignment after. Satisfied customer.
    #31
    ang bilis naman nalaspag ang rear shocks mo! any reason why?
    Jan 2010
    #32
    Napansin ko sa Velocity lately, mas aggressice sila sa ipapagawa mo.
    Amy konting lagatok din ang altis namin at gusto palit lahat ng shocks, mounts na aabot 23k din.
    Hindi ko muna pinagawa kasi may doubts ako sa dami na gusto ireplace
    #33
    Quote Originally Posted by the_jet View Post
    "palitan na po natin lahat. kapag nasira po ang isa, ibig sabihin ay malapit nang masira yung iba."
    "pag pinalitan po natin ang lahat, parang bago namang muli ang kotse nyo."
    logical, but only if one has the wherewithal and is willing to part with it.
    Apr 2005
    #34
    Kapag mainit kasi ulo ko doc, wala akong nakikitang lubak.
    Lately, may clunking na nman sa front sides.
Under Chassis Specialist
