Page 1 of 3 123 LastLast
Results 1 to 20 of 62
    Jan 2009
    Please recommend a shop in Metro Manila that does this properly. Competent mechanics, modern equipment, but not as expensive as casa.
    i have mine done at servitek.
    my tires do not develop patterns of un-even wear.
    Jan 2009
    Which branch?
    Quality of work seems to vary widely by branch.
    Which branch?
    malapit sa otis. tabi ng honda.
    Search mo yun topic about this, marami sinabi doon shops na meron hunter equipment and road force.
    Jan 2009
    Thank you. I didn't know what search string to use.
    At any rate, just wanted an up-to-date list of reputable shops. Maraming posts before but they're old and I don't know how much of those are still true today.
    Aug 2013
    Shell gas station sucat rd. (tapat ng Greenheights Subd)
    dito ako nagpapagawa kasi malapit din sa auto supply (Airad auto supply)
    Hunter yung gamit nila.
    P300 toe correction
    P1300 camber and toe correction
    3 months warranty
    kapag nag avail ka ng change oil promo nila, free toe correction.
    baka alam san yung sa pasig na may hunter? akala ko tama pagkaintindi ko dun sa sinabi sakin noon na directions mali pala ako hehehe
    or kahit QC thanks!
    Aug 2004
    or kahit QC thanks!
    Shell Pasig C5 NB across Mazda has Hunter machines.
    Sent from my SM-A605G using Tapatalk
    salamat bro!
    Sep 2018
    There's a lot of auto shop who provides services like this. I think what you can do is to ask your friends who have the same car type as you have. You can also find a car shop directory online where you can find a trusted car shop who provides service that you need. For sure they have a listing for the best wheel alignment shops that are near your area. You may want to check it out. I hope you'll find this helpful!
    Jun 2018
    Drive+ Panay Avenue, Q.C., sir
    looks pricey dyan bro hehehe
    mahal ng oil change nila sa drive+ looool
    Dec 2023
    Interesting anecdote:
    If I ask an aligner to make my car go straight ahead, it pulls left when I go back out on the road.
    If I ask the aligner to make the car pull right, it rolls straight when I hit the road!
    nagapalit ako ng pang-ilalim kahapon so takbo ako magpa- alignment service maybe tomorrow.
    ang problema may slow leak ata ang isang gulong ko so kailangan patingin ko muna
    Jan 2009
    Quote Originally Posted by TireWhisperer23 View Post
    Wheel geometry is more complex than they appear. A lot of factors... steering, suspension, link/bushing conditions, tire pressure, etc. comes into play. But to your issue, I'm guessing driver weight and even how much fuel you have in the tank (and where it is located) also affects the outcome.
    Try sitting in the driver seat while the aligner zero it down to drive straight.
    i wonder,
    are the usual published suspension adjustment specifications supposed to be adjusted with the vehicle devoid of driver and passenger/load?
    Jan 2009
    i wonder,
    I think the weight ratio between the vehicle and the driver will have something to do with it. Smaller/lighter vehicles with softer suspension paired with a heavyset driver will definitely have a more significant effect on the alignment. In this scenario, the weight of the driver should be factored in.... put him in the driver's seat while the alignment is dialed in.
    Larger vehicles due to their mass, makes the driver's weight somewhat less significant and therefore, potentially negligible.
    Nov 2017
    i wonder,
    For the Toyota products its likely to be the case for most of their products per the service manual/GSIC(atleast for the prev gen hilux & LC) that the alignment be done unladen.
Wheel Alignment
