Results 11 to 15 of 15
January 19th, 2004 03:20 PM #11
Yung Scarab powerboat ko hehehe
Hinde, i just noticed sa manuals na you have to put more air sa rear tires when you do tow.
Originally posted by mbt
pajerokid,
anong tinotow mo?
January 19th, 2004 03:38 PM #12
28-30 psi is a good ballpark. I only go above that when I'm towing (palay) or hauling stuff.
The sticker on my door jamb actually calls for 50 psi. Whatta stupid label.
- Dec 2002
- 2,335
January 19th, 2004 10:20 PM #13fyi: normally pressure will increase by around 2 psi when the tyres are already hot. Measure tyre pressure when they are still cold or make the necessary adjustments when they are already hot
January 20th, 2004 07:52 AM #14Originally posted by Ungas
I have 30psi on all four 33x12.5x15.
It all depends on how your comfort level is, pag na titigasan kayo pagdaan sa mga lubak babaan nyo yung rear (~5). Pag sumbra naman ng lambot dagdagan nyo (~2).
:X sakit siguro non :X
high idle RPM at engine start
