Results 1 to 5 of 5
September 3rd, 2012 08:27 PM #1
can someone clarify how tire measurements are read.
for example stock tire of navara is 255/70/16.
from my understanding, 255 refers to the tire width - meaning yung lapad ng gulong from one side to another? does it contribute to the ride height?
next is 70 which refers to tire sidewall height - is this the one responsible for the ride height? i mean are 255/75 tires taller than 255/70? so if i wanna maximize my ride's height, i should opt for a bigger number here?
well 16 refers to the wheels these tire are mounted on. no need to clarify anymore. TIA.
September 3rd, 2012 08:50 PM #3
The '70' is the height profile from bead to tread and it is the % of the tire width. So the height from bead to tread is 70% of 255 = 178.5mm.
September 3rd, 2012 10:22 PM #4
make sure you use the tire calculator when up sizing or downsizing your stock tires.
- Jul 2008
- 485
September 4th, 2012 03:56 PM #5going wider (265) while maintaining the profile (70) will also increase the ride height since the overall diameter of the tire is increased. you can also go by maintaining the width (255) and increase the profile (75) to increase the height.
so if you really want to maximize the ride height and the wheel well can accommodate it bigger tires, then move a notch in width and profile.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
