Results 1 to 10 of 24
June 22nd, 2005 11:59 AM #1
on all four tires maspudpod ang nasa outer thread ng tire.yung nasa loob makapal pa. what could be the cause of this? is it safe to flip the tire? backside will be the frontside na.
June 22nd, 2005 12:22 PM #4
if its the toe in alignment. then bakit pati ang likod? is it ok to flip the tires?
June 22nd, 2005 12:23 PM #5
pwede din under-inflated lahat ng tires, so the tendency is the outer rim sags and gets worn out first. Kung toe in...sa harap lang dapat yung worn out pattern, malabo naman na pati yung rear tires naka toe in. best if you bring it to the nearest servitek.
- Sep 2004
- 340
June 22nd, 2005 12:37 PM #7
basta suspension problem yan or incorrect tire pressure. most probably your front and rear camber needs to be checked and corrected. check your shocks if they are still performing well.
June 22nd, 2005 12:39 PM #8
I think I should also get my tires checked.Mejo madalas na kasi na mejo lumalambot ang tires. is it ok to flip the tires?
June 22nd, 2005 12:43 PM #9
to answer your question about flipping tires check first kung uni directional (performance tires usually are uni directional) ang tires mo. most tires especially passenger tires pwedeng iflip dahil bi-directional sila. pero kung performance tire yan i doubt kung pwede.
- Sep 2004
- 340
June 22nd, 2005 12:47 PM #10in the case of underinflated or overinflated ang gulong, dapat nasa both outer thread ang pudpod and center thread pag overinflated.so definitely camber allignment and suspension check-up ang kailangan mo.but flipping the tires would be ur cheapest alternative.
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
