Results 1 to 10 of 34
- Jun 2013
- 120
June 17th, 2013 10:46 PM #1Good day. My new AT CR-V slips backwards even after pressing the foot brake (full force). What I do to test is go uphill, stop, set to neutral then put on the foot brake. Honda technician said that it does happen because of the weight of the vehicle. Is what he said true, or should I have my car picked up and checked in casa?
- Jun 2013
- 120
- Jul 2003
- 573
June 17th, 2013 11:35 PM #3normally, in going uphill or in steep incline, you should apply the hand brake. foot brake is not strong on the rear wheels. foot brake is designed to stop the car while moving forward, and applies strong braking force to the front wheels only.
June 17th, 2013 11:38 PM #4
I think sir sparton is referring to foot brake not the brake pedal. No hand brake available.
- Jul 2003
- 573
June 18th, 2013 12:31 AM #5interesting, does the foot brake in a CR-V replaces the normal hand brake lever? If so it should lock the rear wheels and prevent the car from
moving. If it slips, then it definitely needs adjustment.
Sparton, when the car moves, can you tell if the wheels are sliding/slipping or turning?
- Jun 2013
- 120
June 18th, 2013 12:43 AM #6Sorry for not being clear. I'm referring to the foot-operated parking/emergency brake. As far as i can remember, the wheels are not sliding nor turning. Just rolling backwards. But for some weird reason, parking brake seems to work when going downhill. The dealer technician said that it can be because of gravity especially because of the vehicle's wait. I may need to have them pick up my car for casa checkup.
- Jul 2003
- 573
June 18th, 2013 09:13 PM #8
June 18th, 2013 09:18 PM #9
Hand brake levers are easier to access and easier for controlling braking power. The tendency with a foot brake is for the driver to push it all the way down thus applying the brake's full force. Besides, if you're drifting, your feet would be busy with the foot pedals.
June 19th, 2013 10:19 AM #10
Anong yr model sa inyo? Nakasaad ba sa manual na supported Wifi Display sa unit nyo?
2016/2017 Isuzu MU-X
