Results 21 to 26 of 26
November 3rd, 2009 10:22 AM #21
try pa ayos ang caliper mo, lilinisin ito at kung sira na mga rudder at seal kailangan mo ng repair kit, baka nag stuck na ang caliper kaya maingay, kapapaayos ko lang(front only), labor 500pesos, repair kit 350 pesos and brake fluid 90 pesos.
Tsikot Member Rank 4
- 1,842
November 15th, 2009 12:50 AM #23
Pwede rin po loose caliper. Eto naging case saken. Usually yung squelling sound nya pag magaan lang ang apak ko. Pag mabigat naman, nawawala.
November 20th, 2009 01:12 AM #24
Apply brake paste on the back, not on the face that contact the rotor, of the pads. Yun wear pad indicator noise iba sa brake squeel. Parang may nagagas na metal tapos pag apply mo ang brake nawawala. Yun brake squeel pag step mo sa pedal dun siya tutunog.
- Oct 2009
- 44
November 20th, 2009 02:43 AM #25Answer mo muna if the car brakes at all perfectly? If it does get a brake cleaner. Spray mo nalang dun sa area. Maybe its just some stucked up dirt. How loud does it sound ba? Loud enough to wake up the neighbors late at night? Make sure those bum heads installed the break pads in the correct position. Baka bailktad and metal to metal naririnig mo. I heard those stories na. Installed break pads na baliktad lolz.
- Oct 2008
- 38
October 1st, 2013 02:50 AM #26'eto naman po ang nangyayari sa kotse namin: when I have driven through any water or in the rain the right front brake produces a whistle sound.
is this an indication to change the brake pads? or it would be something else?
thanks in advance!
Xiaomi E-Car
