Results 1 to 10 of 10
- Dec 2008
- 26
March 3rd, 2010 04:03 PM #1My car (Toyota Altis, 2003, 1.6E) due for replacement na yung steering rack end. One shop recommended to replace also the tie rod end. Kailangan bang palitan na din yung tie rod end (kahit ok pa) kung magpapalit ng steering rack end.
TIA
March 3rd, 2010 04:34 PM #2
2003 MODEL - sabay talaga pinapalitan yan, para pag nagpa 4 wheel aligment at camber ka isang gastos lang.
- Dec 2008
- 26
March 3rd, 2010 05:07 PM #4
usually the inner tie rod goes out first followed by the tie rod end. if the tie rod end passes the articulation test, it should still be okay to reuse. articulation test is done while holding the threaded taper end and watching the body if it holds up against dropping from gravity. if it still could maintain its position, the tie rod end is still serviceable
- Dec 2008
- 26
March 3rd, 2010 08:54 PM #5*jick - Thanks. Just another inquiry, the inner tie rod is the same the steering rack end in Altis? I am looking in some pictures/diagrams parang parehas sila. Thanks again
March 4th, 2010 05:38 AM #6
there are two major pieces to the tie rod aside from the jam nuts or locking devices: the part connected to the steering knuckle is the tie rod end ( this the part where the two sections form a 90 degree angle). the other piece is the inner tie rod which is connected to the steering gear (rack and pinion) assembly. the inner tie rod usually comes ambidextrous. the tie rod end sometimes are driver side or passenger side oriented. but they all are right hand threaded.
- Dec 2008
- 26
March 9th, 2010 07:24 AM #8
March 9th, 2010 08:47 AM #9
Hmmm, most mechanics should know about that. Just tell them you want to visually check if the tie rod end is still good. They'll do the gravity test so you can see for yourself.
It's simple enough actually. They'll just decouple the tie rod end from the steering knuckle (this part is on the wheel hub), and let it drop while it hangs from the rack end. I've seen this done on my old 1999 SX8 Honda City and it did drop, so it was time for replacement. Sorry no photos but I think you can get the general idea.
HTH
March 9th, 2010 06:33 PM #10
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
