Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
    Oct 2007
    #21
    wow! thanks for this thread! akala ko kung ano nang problem ng suspension ko. kasi i experience that also. yung kumakabig sa uneven roads. hindi na kasi pantay kain na gulong ko before i had it aligned and cambered. kakapagawa ko lang naman sa casa buong steering/suspension ko.i really need a tire change. thanks guys!
    Oct 2007
    #22
    problem is hindi naman na kayang i-wheel balance pag uneven na ang kain ng gulong hehehe... thanks ulit!!!
    Aug 2007
    #23
    > Additional info for troubleshooting the steering
    Steering wheel is hard to turn :
    You find that it is getting more difficult to turn the steering wheel. It feels like something is binding or dragging. This may or may not happen suddenly or is getting worse over time.
    Possible causes:
    1. Low tire pressure: Check and adjust tire pressures.
    2. The wheels are out of alignment: Have the wheels aligned.
    3. The power steering box or rack or power steering pump is bad: Repair or replace steering gear or pump as required.
    4. The fluid level in the power steering reservoir is low: Fill fluid to proper level.
    5. The power steering drive belt is damaged or broken: Replace power steering drive belt.
    6. The steering gear needs to be lubricated or repaired: Lubricate or replace steering gear parts as required.
    Hard steering:
    You notice it takes much more strength to turn the steering wheel. This is especially noticed when you are trying to park. The problem seems to be getting worse.
    Possible causes:
    2. The steering gear needs to be lubricated: Lubricate steering gear parts as required.
    3. The wheels are out of alignment: Have the wheels aligned.
    4. A part of the steering linkage is damaged and doesn't not move freely: Replace steering gear parts as required.
    5. Your steering box needs to be adjusted: Adjust steering box as required.
    6. You have a problem with the power steering pump: Repair or replace power steering pump as required.
    Loose steering:
    You notice that the steering wheel is very easy to move and actually feels quite sloppy. It creates an uneasy feeling on the highway because it seems you have no control of your car. The problem seems to be getting worse.
    Possible causes:
    1. Steering linkage is worn and parts need to be replaced: Replace affected parts.
    2. Parts of the steering linkage are loose and need to be tightened: Tighten or replace loose parts as required.
    3. Your steering box needs to be adjusted: Adjust steering box as required.
    Power steering doesn't seem to be working:
    It takes a lot of effort to turn the steering wheel. In fact, at low speeds you can hardly turn it. The problem is less obvious at high speeds simply because you need to move the steering wheel less at those speeds. The problem may have occurred suddenly.
    Possible causes:
    1. No fluid in the power steering reservoir: Fill fluid to proper level.
    2. You have a bad power steering pump: Repair or replace power steering pump.
    3. The power steering drive belt is broken: Replace power steering drive belt.
    4. The fluid in the system is contaminated: Flush power steering out power steering fluid and replace with fresh clean fluid.
    5. You have a steering linkage problem: Repair or replace linkage parts as required.
    6. There is a leak in the power steering lines: Replace power steering lines as required.
    7. Low tire pressure: Check and adjust tire pressures.
    Car pulls to one side while moving:
    As you drive the car tends to pull to one side or the other. You need to constantly hold the wheel firmly to keep the car going straight. This will have happened over time. When the problem is slight, it often is dismissed and only severe pulling is noticed.
    Possible causes:
    1. Tire pressures are not equal: Check and adjust tire pressures.
    3. One brake is dragging or isn't releasing: Check brakes and repair as required.
    4. Parts of the steering linkage are loose and need to be tightened: Tighten or replace loose parts as required.
    5. The car's tires are not worn evenly: Replace tires as required.
    The car seems to wander down the road:
    As you are driving, you notice that you must constantly correct the direction of the car by turning the steering wheel.
    The problem seems to increase, the faster you travel. This problem may occur gradually and get worse over time or it may appear suddenly.
    Possible causes:
    1. The car is overloaded, or the weight is unevenly distributed: Lighten the load or equalize weight distribution.
    3. The car's springs are weak: Replace springs.
    5. The front wheel bearings are out of adjustment or are severely worn: Adjust wheel bearings or replace as required.
    Steering wheel jerks:
    When you are driving slowly or at an idle the steering wheel jumps or jerks. You don't see any other problems as far as steering and handling go. As time goes by it seems to be getting worse.
    Possible causes:
    1. The power steering drive belt is damaged or loose: Tighten or replace power steering drive belt as required.
    2. The fluid level in the power steering reservoir is low: Fill fluid to proper level.
    3. The engine is idling too low: Adjust idle speed.
    4. You have a problem with the power steering pump: Repair or replace power steering pump as required.
    5. The steering linkage is rubbing against something: Inspect steering gear and repair the interference.
    Steering wheel vibrates:
    At about 45 to 60 miles per hour the steering wheel begins to vibrate. You also notice that the car is also vibrating or twitching. This can be very dangerous. If you notice the problem only occurs when you step on the brakes, it will make diagnosis simpler.
    Possible causes:
    1. Warped or damaged brake rotors and/or drums: Resurface or replace brake rotors and/or drums as required.
    2. Loose wheel lug nuts: Tighten wheel lug nuts.
    3. Out-of-balance wheel and tire assemblies: Balance wheels.
    5. Bent or damaged wheels: Replace bent or damaged wheels.
    6. Severely worn or damaged tires: Replace tires.
    Wheel shimmy:
    You notice a side-to-side wobble in the steering wheel when traveling at steady speeds. The vibration gets worse when you are on an uneven road surface or after going over a pot hole.
    Possible causes:
    2. Out-of-balance wheel and tire assemblies: Balance wheels.
    3. Worn or damaged tires: Replace tires.
    5. You have worn suspension parts: Replace suspension parts as required
    Noises while turning a corner:
    You notice a knocking, clunking, and/or squeaking noise while you turn a corner. Everything else seems to be fine except for the noise. The problem seems to be getting worse over time.
    Possible causes:
    1. The steering gear needs to be lubricated or repaired: Lubricate or replace steering gear parts as required.
    3. Your tires are hitting or rubbing against something: Locate the interference and repair.
    4. You have worn suspension parts: Replace suspension parts as required.
    5. Something is rubbing against or hitting the steering column: Locate the terference and repair.
    Noises from the power steering unit:
    You notice a whining or moaning from the steering when you turn the steering wheel all of the way in one direction.
    Possible causes:
    2. The fluid in the system has air in it: Bleed power steering system.
    3. The fluid level in the power steering reservoir is low: Fill fluid to proper level.
    4. The mount for the power steering pump is loose or damaged: Repair or replace power steering pump mounts as required.
    Oct 2007
    #24
    wow great info! thanks!!!
    Jan 2008
    #25
    Hi there, pwede ko na rin po ba intanung sa inyo dito kung san maganda magpagawa regarding sa power steering.....lately po kasi may tagas ang power steering ko....sabi ng mekaniko ko sa rack end daw po....any help and advice...thanks...
    #26
    Quote Originally Posted by threed View Post
    pakisearch nalang, type mo "power steering"
steering problem
