mga chief ano ba ang problem kung kumakabig ng kusa ang steering wheel pag uneven ang daan?
i've been experiencing this lately sa innova ko. ano ang mga kailangan i-check or paliltan?
thanks
thanks
sir try nyo muna i pa wheel alignment baka makuha po sa ganun paraan....
pero hintayin pa natin ang ibang expert..
tnx
Another austere measure would be wheel balancing. Baka ganun lang kasimple problema mo. HTH
both posters are actually right. it can only be a simple case of alignment and/or wheel balancing.
start small, minsan kasi, dun pa lang solve na ang problem ng oto mo eh.
Possible din ba na maging cause ng pagkabig ang hindi pagkakaroon ng pantay na hangin sa 2 harapang gulong?
Worst thing might be the car having a case of "bump steer." That's related to one of the suspension settings, I can't remember which particular one at the moment.
possible din ba ng kailangan ng camber correction? hindi parang hindi kasi pantay ang kain ng gulong. mas nauuna mapudpod ang inner side ng tires ko although hindi halata kung hindi titingnan mabuti
sir, check niyo muna ang Tire Pressure kung nasa tamang setting. also, check for possible uneven tread wear sa gulong. but anywayz, kung ok naman ang tire pressure and tread wear, then I suggest you to do a test drive on a flat (even) road, para ma test ng maayos kung kumakabig pa din ang manibela (or if the car is drifting to one side or the other). diyan mo malalaman ng mabuti kung kailangan mo na ng Alignment. also, kung nag va-vibrate naman ang manibela (specially * 60 mph (90-100 kph??), then Balancing naman ang kailangan mo.
aite, peace.
well, it could be the Camber or the Toe adjustments. kung mas malaki ang wear sa inner side ng gulong then you have a Negative Camber (or Positive Toe..) but before doing anything, jack up the front end of the car and see if theres any worn suspension bushings and ball joints. check for worn out Tire Rod ends as well.
aite, peace.
Never heard of "bump steer." But I have heard of "bum steer," which in journalistic parlance means "nakuryente" or a reporter given wrong information by his source.
thanks guys... i will have it checked this saturday. balitaan ko kayo kung ano ang verdict ng gagawa
"Bump steer" is a term for the thread starter's symptoms that I've read about somewhere.
Let's say the vehicle in question has excessive bump steer. When the vehicle is travelling in a straight line and the front wheels encounter a bump in the road, the tendency is for the said wheels to develop play in the milliseconds that they lose contact with the road, and "steer" themselves at an angle instead of going in a straight line. This is happening without any input from the steering wheel.
http://en.wikipedia.org/wiki/Bump_Steer
It's just a suggestion. I think it can be cured by alignment too, though.
yung uneven roads ba na sinasabi mo ay yung parang W yung hugis ng kalye parang wave dahil sa dumadaan na mga overloaded vehicles at di maganda quality ng pagkakaaspalto or semento (thanks government)?
uneven kasi yung iba bagong latag ang aspalto and yung iba hindi pa tapos. minsan sobrang lakas ng kabig kaya delikado kung mabilis ang takbo
ah kala ko yung dinescribe ko yung tinutukoy mo kasi kapag ganun natural talaga na kumabig mag isa lalo na kapag mas malalim yung pagkalubog, kaya ang solusyon ko is idaan yung gulong sa nakabukol na area nung kalye para dretso parin
minsan kahit hindi malalim ganun pa din. basta may uneven surface kakabig yung steering wheel. dati kasi hindi naman ganun
ah ganun ba, well tama yung mga suggestions na nakapost above.. first thing to do is check your tire pressure, pag ganun parin, pa wheel balance, then kapag ganun parin, wheel alignment na( pero check mo muna kapag kumakabig sa kaliwa or kanan kapag tumatakbo ka ng medyo mabilis around 60-70kph or minsan ang kabig pag nagppreno ka). check mo din kung tama ang upod ng mga gulong mo lalo na sa harap
normal lang naman na gumalaw ang steering wheel kapag nalulubak., lalo na kung hindi power steering. ang hindi nomal ay ang sinasabi mong wear sa inner side ng tires. better bring it for wheel alignment. duon makikita nila kung may kailangang palitan sa under chassis bago gawin ang alignment
