Results 1 to 10 of 10
- Jul 2013
- 8
August 22nd, 2013 01:08 PM #1Mga bossing may alam ba kayo gumagawa ng issue ko. Honda City 08 sya kung nag mamaniobra ko di bumabalik sa center yun steering wheel ko manual ko pang ibabalik. Dinala ko sa Servitek di daw nila kaya eh. any shop malapit sa las pinas?
August 22nd, 2013 01:12 PM #2
August 22nd, 2013 01:19 PM #3
electric power steering ba yang unit mo? non-centering na ata yung mga naka EPS kaya di talaga babalik sa center.
- Jul 2013
- 8
August 22nd, 2013 01:45 PM #4di ko alam eh. yun isang honda city 08 ng barkada ko ganun din eh. kung normal lang pala ok lang.
- Jul 2013
- 8
August 22nd, 2013 01:53 PM #6yes pag U turn di bumabalik sa sentro stuck lang sya not unless ikabig mo manualy. napa-camber and align ko na sya 2 months ago using R15 rims,
- Apr 2010
- 268
August 22nd, 2013 02:13 PM #7Something to do with self centering mechanism. Check the whole linkage sir. Baka may leaks or bushings/boots/seals to replace.
Peace out!
- Sep 2013
- 1
September 22nd, 2013 08:17 AM #82008 city is driven by EPS wala syang power steering fluid i have the same situiation i ask honda tech. normal lang daw yun ,,,,,, i hope so!!,, i ask naman some of my friend very complicated daw kapag yung EPS natin yung nag kaproblema,,,
- Jun 2010
- 321
September 22nd, 2013 10:33 AM #9ganyan din yung glx-v limited namin di bumabalik , normal lang daw sa glx-v limited
October 9th, 2013 01:40 PM #10
I had the same kind of problem a while back. I had my steering checked and my underchassis checked. Walang problema. Pero hindi pa din siya bumabalik sa center specially if fully turned yung wheel.
So I had to live with the problem until I decided to correct the camber of my car an voila! Naayos yung steering wheel ko. Apparently, my SUV had a positive camber on both wheels and that caused the steering wheel to not return to the center. Search niyo na lang yung camber if you're not familiar, and minutong makita niyo illustration ng positive camber ma-gets niyo agad kung bakit hindi siya bumabalik ng kusa sa center
^Thanks for the advise guys. Already replaced all.
Rubber boot question (repair or replace)
