Results 1 to 5 of 5
    Nagpalit po ako ng 2 gulong sa front. Nanotice ko na after palitan ung 2 gulong sa front, naging sobrang talbog na po nung andar ko unlike before na hindi naman. Dati kasi 4 goodyear tires sya tapos ngayon, 2 goodyear sa likod, 2 nankang sa harap if it makes any difference. Pinacheck ko ung psi ng gulong 30 naman lahat. Ano po kaya problema nito...
    Sep 2012
    Since bagong palit tires mo pa check mo mga items below tapos ganyan
    1) Camber Correction and Wheel Alignment
    2) Check the condition of the Shock Absorbers and other suspension parts
    Good practice na rin kasi yung item 1 once nagpalit ka ng set of tires
    Feb 2009
    Quote Originally Posted by sano011 View Post
    if your ride is too harsh, it may be due to higher than recommended tire pressure or higher than recommended load range tire for your car. check to see that our tires are passenger car tires, this would have the "P" on the sidewall, e.g.; P185/65R13. if it is too bouncy, it may be due to your worn out shock absorbers or low tire pressures
    Jul 2011
    sir pag nagpalit ka ba ng tire size (175/65R15 -> 195/50R16) same pa rin ba ung recommended tire pressure?
    Sent from my GT-N7100 using Tapatalk 4
    Jul 2012
    Pa check mo ung tires mo baka naman may bukol delicado un hehe.
    Uhmm try to check ung sinabi ni sir jodski if hindi parin pa check mo na shock absorbers mo.
Bouncy Ride
