Results 1 to 3 of 3
- Nov 2004
- 45
August 13th, 2009 05:09 PM #1Good day fellow forumers!
My ride have this squeeking sound while running. Kinda high pitched. When I press on the brakes the sound stops.
Previous history: My bro used it in the flood unfortunately.
Please do help what possible problems that it has?
Ride : Lancer Itlog
Thanks in advance
- Jan 2009
- 121
August 13th, 2009 05:19 PM #2Have the brakes checked and cleaned since when braking, the sound stops.
August 13th, 2009 05:21 PM #3
Best way you said it is use in flood . If front is disk brake check brake pads, piston inside might have a stock up. and also both the rear brake might be a drum brake.Must check also of worn brake pads.
Suzuki JIMNY [merged threads]
