Results 1 to 13 of 13
    Aug 2007
    guys usually ilan years po sila pinapalitan? yun sa akin po kasi 1 year pa lng 15-16k na yun takbo then nagpa 20k maintenance ako.. sinabi sa akin 1/4 nalng daw yun brake pads and change roto disc asap.. hindi po kaya pinalitan ng planta? or talagang 1 year(15-16k un takbo) lng need na palitan?
    What car and year/model?
    Anyway, brake pads tend to be replaced between every 10,000 Km or longer.
    Brake rotors will last for years (ten or longer) as long as it's not abused hard during it's use. If the rotor is cracked or warped, it will need to be replaced.
    Aug 2006
    Quote Originally Posted by haihuat View Post
    What model/make year?
    M/T or A/T?
    Change brake pads at 20K is too early. Unless you use the car for drifting
    Yung Innova ko running 70K ++ makapal pa brake pads, mabigat pa yung Innova ko plus 8 passengers daily.
    Jan 2009
    Wow! I'm also around that mileage (1.5 years * 15,+++ km; Civic 1.8S A/T). And I think there's still roughly 50-60% brake pad life left in front and 70% at the rear. You usually replace the rotors only after running through maybe 4-6 sets of brake pads at least. Either your speculation about the casa replacing them with spent ones is true or you have heavy feet.
    If it's the latter, you may want to review your driving habits. Use engine braking when possible and avoid rapid acceleration and sudden stops.
    What sort of roads do you travel on; Hilly/Mountainous? City? Highway?
    When did you have your last PMS? What was the mileage and thickness of the brake pads?
    Aug 2007
    nissan navarra last year july ko lang binili and now i need to change the brake pads(1/4 na lng) and roto disc asap.. i always drive at highways all the time NLEX then SCTEX.. nagulat na lang ako na ganun na pala yun brake pads ko after the maintenance... kaya may duda ako na pinalitan nila..
    i just have my PMS last week.. my mileage now is 16k
    Get second opinion bro.
    SHARING IS CARING.....
    16,000 and you need to change the pads lalu na yun rotor? Grabe ah baka palaging hard braking ka or something fishy going on sa CASA.
    i rememered, that when i changed by lancer's pads, it was at the 110k km range... hehehehe.
    actually, you can have it checked DIY mode... pag tanggal mo ng gulong mo, masisilip mo kung makapal pa yung brake pads or not.
    Do you do a lot of hard stopping from high speeds? Do you feel a loss of braking power? Do you hear a squealing noise?
    If not, go for a second opinion with another Nissan CASA.
    Aug 2007
    sometimes pero hindi naman parati.. highway kasi lagi takbo ko.. kaya nagtataka ako biglang 1/4 nalang yun brakepads and pati roto disc nadamay sa loss of braking power sa ngaun maayos naman pagkabrake ko kumakagat pa naman yun squealing noise mahehear ko yun kapag hard stop from high speeds or kapag wet un daanan.
    hindi yata pwede pagpalit ng nissan CASA kasi nagsend ng flyers yun nissan kapag pinagawa mo sa ibang nissan or sa labas ng nissan hindi na nila sagot yun warranty mahirap naman sisihin yun CASA kasi no proof and sa loob nila ginagawa so hindi natin makita if pinalitan or hindi..
    kunan mo pix yung rotor then post mo dito
    Para mas analyze ng mga tao dito,
    Hindi puede sa ibang nissan casa?
    yan ang isa sa ayaw ko sa nissan, parang laging disorganize sila. Minsan mga dealership nagsisiraan sa isat isa.
    dapat puede sa ibang nissan iyan!
    Anyway, kahit pa check mo sa labas ang brakes mo, in the end hindi naman nila malalaman na pinagawa mo sa iba. or kahit ipacheck mo lang.
    Jan 2003
    Take into consideration na rin yung compostion ng brake pads. The OEM Akebono pads na gamit ng Nissan is much friendlier sa rotors. I noticed this kasi with our Xtrail. Yung original pad nya does not produce a lot of brake dust.
    When the casa recommended to replace it, and we gladly obliged, ayun ang lakas ng brake dust. Bilis din maubos. I checked the old pad, may 50% pa. Better check the pads yourself and decide if you need to replace it na.
    Much more practical to use Bendix Standard pads which I'm using now. Costs 1/4 than OEM. Or better yet go for the performance pads like Tanabe, Project Mu or EBC. Almost same lang ng price ng OEM.
    Sep 2008
    I just changed my front rotors and brake pads ( Powerplus and Bendix CT respectively ) * 192,000+ kms. OK po kaya ang combination nila?, TIA
brake pads and roto disc
