Good day fellow forumers! My ride have this squeeking sound while running. Kinda high pitched. When I press on the brakes the sound stops. Previous history: My bro used it in the flood unfortunately. Please do help what possible problems that it has? Ride : Lancer Itlog Thanks in advance
Have the brakes checked and cleaned since when braking, the sound stops.
Best way you said it is use in flood . If front is disk brake check brake pads, piston inside might have a stock up. and also both the rear brake might be a drum brake.Must check also of worn brake pads.
