Page 1 of 3 123 LastLast
Results 1 to 20 of 44
    Oct 2013
    Hi
    Patulong lang mga co-Tsikoteers
    Car: Avanza
    Last Oct 2014, nag replace ako ng brake pad and pina re-face yung rotor plate due to rough na sia. So, ok sia until this last 2 weeks, mejo may squeaking sound ung front-left part.
    Nag squeak sia after est. 10 mins of running pero pag initial pa lang, walang squeaking sound.
    Pina cleaning ko na rin yung brake pad and rotor twice pero ganun pa rin yung problem. Kung titignan mo yung rotor, smooth surface naman sia.
    Yung front right naman, ok naman sia.
    Ano kaya pwedeng solution dito?
    Thanks in advance
    probable causes:
    because of moisture
    brake pad wear
    el cheapo brakepads which contain high metal
    rust between the pads and the rotor
    rusted drums
    i am assuming its the moisture, since napalitan mo na ang pads mo and nagpa reface ka na..... medyo maalimoom pa naman ngayon sa umaga.
    probable causes:
    because of moisture
    brake pad wear
    rusted drums
    Feb 2009
    That's the problem, anytime you machine or resurface brake drums and rotors you are supposed to wash the new surface with soap and water to remove the cast iron dust. If you don't the dust coats the brake pads and when you apply the brakes, the cast iron rotor or drum rubs against the iron coated brake pad/shoe and squeals like the brakes on a train
    Dec 2009
    try to use break grease.... kung saan mo piangawa ng breaks mo.. bili ka ng magandang klaseng break grease...
    palagyan mo guide pins/ shims/ caliper bolt/ etc....
    pag ayaw pa din mawala it only means one thing, nung nagpa-reface ka ng rotor the resulting finish is not 100% flat or within acceptable rotor run-out...
    Dec 2009
    Quote Originally Posted by misterioman View Post
    Hi
    Car: Avanza
    Thanks in advance
    ano pinalit na brakepads? replacement bendix nowadays hindi na maganda quality(based on my experience).. kaya OEM ako pa lagi
    Quote Originally Posted by junerski View Post
    Yup, normally pangit lang ang pad na ginamit mo. Mag OEM ka muna per what Junerski recommended para malaman mo yung difference.
    May 2009
    Quote Originally Posted by miko101130 View Post
    wag yung petroleum based grease ha TS (multipurpose, EP grease,etc.). yung silicone type brake grease. rubber friendly iyon. di nga lang budget friendly. pero sure naman na tatagal.
    ok naman kaya ang installation ng anti-squeal shims kung meron man? subukan mo kayang ipa-chamfer yung edges ng brake pad gamit ang file. pero slight lang ha.
    Apr 2009
    clean all your brakes front and rear. if your brakes still squeal, then its probably you have a bad quality of brakepads installed, and its best to swap in an OEM pads....
    Oct 2013
    san kaya pwede bumiling ng OEM na brake pad for avanza na hindi sa Casa?
    Sep 2005
    use brake shim....
    May 2012
    any update on this mga sir? same problem din nun sa akin, nagpa reface din po ako ng front disc and palit break pads (Bendix) pero after ilang araw lang may langitngit sound na pag nagcocontact yung pads sa disc.. hindi ko parin maayos..
    Jan 2008
    bili ka ng copper grease sa concorde nasa tube yun. tapos palagyan mo ng copper grease yung likod ng brake pad na may contact sa caliper. medyo kapalan mo yung grease
    May 2013
    mukhang totoo ito. i replaced my pads using bendix last year, may squeaking sound na din na parang metal to metal.
    May 2012
    Quote Originally Posted by gutz_3110 View Post
    same here last month pako nagpalit ng bendix kala ko mag bed-in lang then mawawala yung maingay pero hindi parin nawawala yung squiking sound. nagpalit narin ako ng brand new rotor disk last week kase ma vibrate na pero andun parin yung ingay. ano kaya iba magandang brand?
    Quote Originally Posted by monackz View Post
    get OEM/genuine brake pads for your car.. call Casa for price comparison vs buying sa suking genuine parts auto supplier kasi minsan masmura pa sa casa
    Jan 2014
    You might try Rico brand.. minsan lang maingay sir. Malambot ang brakes pero makapit. Kapapalit ko lang ok naman sya. Need lang sa likod. Probably Mikasa brand (orange) sa likod.
    Apr 2015
    Try rspec japan.
    Sep 2013
    +1 here. salable and consumables items are not much difference between casa vs suking auto supply. casa buys bigger volumes = bigger discounts but the overhead is quite high though
Squeaking sound (Brake)
