Last Oct 2014, nag replace ako ng brake pad and pina re-face yung rotor plate due to rough na sia. So, ok sia until this last 2 weeks, mejo may squeaking sound ung front-left part.
That's the problem, anytime you machine or resurface brake drums and rotors you are supposed to wash the new surface with soap and water to remove the cast iron dust. If you don't the dust coats the brake pads and when you apply the brakes, the cast iron rotor or drum rubs against the iron coated brake pad/shoe and squeals like the brakes on a train
