Results 1 to 8 of 8
    Mga tsikot Guros,
    Tanong lang about a squeaking sound coming from the suspension arm area every time I brake or traverse an uneven road. I tried jerking the front driver side pero hindi ko malocate ang pinag gagalingan. Sa right side lang nag gagaling. Baka lang may naka experience na ng ganon ingay. Maraming Salamat!
    Aug 2006
    First thing I would do is jack the car up and see if everything is well tacked... Check your bushings, mounts, spring pads, etc...
    Oh, and when asking such questions, don't forget to give more info about your ride...
    Blink,
    Isuzu Trooper, UBS69.
    Thank you. Did that already di ko pa rin ma pin point kung saan galing. I have soaked all the bushings with oil and yet meron pa rin squeaking.
    Sa mga Jap SUV tsikoters, advece namn in case you had or have the same suspension problem.
    Sep 2006
    Not familiar with your car but try to inject grease if you can't remove the bushings.Usually worn out bushing are the one causing the squicky sound.
    you soaked the bushings with oil? bid them farewell as oil and rubber dont mix, it will make them soft and break faster. have you looked at the ball joints? check the rubber if they are torn, if they are they might be rusted inside.
    Salamat sa mga payo ninyo.
    Pinaliguan ko siya ng oil. Tumulo din naman yung excess. I also tried injecting oil sa upper and lower ball joint para ma lubricate.
    More power po sa inyo!!
Squeaking Noise at the front suspension!!
