Results 11 to 20 of 24
- Feb 2009
- 41
February 7th, 2010 11:20 PM #11its a M/T and it has its own reservoir...i know that it cant be my kit cause the reservoir is still full...its been puzzling me and its frustrating...i just kept bleeding the brakes and it just wont work...
February 7th, 2010 11:24 PM #12
- Feb 2009
- 41
February 7th, 2010 11:33 PM #13
February 7th, 2010 11:56 PM #14
I think you have a leak in one of your brake lines.
If the problem keeps coming back even though you've bled the system time and time again, you should probably have your brake lines looked at. Unless you take care of the leak, air will keep getting into your brake fluid and you will still get spongy pedal feel.
Check your underchassis for areas where paint has been stripped or melted clean off. That's where your leak probably is.
- Feb 2009
- 41
February 7th, 2010 11:59 PM #15
February 8th, 2010 06:38 AM #16
try checking the contct between the master ccylinder and the brake booster. the m/c might need to be reconditioned. there might be an internal leak too between the primary piston and the secondary pisto.
is your brake system diagonal split or front/rear split? is it anti lock brake system?
- Aug 2003
- 9,720
February 8th, 2010 07:07 AM #17nung pinacheck ko ung brakes several years ago, i found out that only one side was working. It seemed that only one of the rubber thingies inside the cylinder was getting pushed forward when i stepped on the brakes, ung isa naiiwan.
Apparently We ended up having the master cylinder replaced and a new repair kit installed. We also found a leak in one of the rear tires(forgot what that thingy attached to the drum brakes was called)
February 8th, 2010 09:51 AM #18
- Jan 2009
- 123
- Jan 2009
- 123
February 8th, 2010 11:49 AM #20
of course! the former was more enlightening than reading the Holy Book. mom loved the Ten...
Traffic!
