Results 1 to 10 of 24
- Feb 2009
- 41
February 7th, 2010 09:16 PM #1here is my story...
i was driving the other day and all of a sudden my brake pedal went soft. so i decide to pull over to a gas station and checked if i had any brake fluid in the reservoir...it was empty!!! i then i fill it up to the max level...and still my brakes were spongy. when i get home...i check the reservoir...it was till full. so i figured i needed to bleed my brake system and so i did. STILL SPONGY!!! what seems to be the problem? should i change my brake master kit? or could it just be my brake lines? thanks in advance...
February 7th, 2010 09:37 PM #2
hindi ba parang may mas malalang problem sir ang brakes mu. the brake fluid canister can't go empty without a major problem. in the gasoline station, did you just top up your brake fluid or did you check for problems?
February 7th, 2010 09:47 PM #3
sorry double post. lagger
- Feb 2009
- 41
February 7th, 2010 10:23 PM #4yes i just filled it up and never checked for problems...i figured it was just empty...cause it happened to me before. BTW, when i brake, my car veers to the right...its seems so that the brake on the left is not working...also, when i bled my brakes...the left brake had alot of air in it...
February 7th, 2010 10:49 PM #5
February 7th, 2010 10:50 PM #6
- Feb 2009
- 41
February 7th, 2010 10:55 PM #7i bled all four brakes...the brake that had the most air was the front left. its a 94 accord...i bled all four brakes and it did nothing....
February 7th, 2010 11:00 PM #8
- Feb 2009
- 41
- Feb 2009
- 41
February 7th, 2010 11:05 PM #10its a M/T and it has its own reservoir...i know that it cant be my kit cause the reservoir is still full...its been puzzling me and its frustrating...i just kept bleeding the brakes and it just wont work...
Daming issue ng SU7:grin:
Xiaomi E-Car
