Results 21 to 30 of 148
October 4th, 2007 03:56 PM #21
I think it's a test for popular "performance oils".
I'd also like to see results for Liquid Moly, Eneos and some other brands.
The heat was worrying me, but... think about it... a lot of the metal on metal wear and tear inside the engine occurs during cold starts.
While the effects of additives are dubious because they break down under heat, most of these commercial oils should be stable at heat... they're designed not to thin out at high temps... so cold-starts should give a good idea of how they perform throughout their heat range.
Still, I'd like to see a retest of those synths and fully-synths that had backwards results at full operating temps... as I think it's just the thicker cold rating viscosity that's making the semi-synths outperform their expensive cousins.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 7th, 2007 11:00 AM #22Royal Purple is available in the ff:
Speedyfix
ERL
HRC banawe
Kanzai
Fusion R
Speedtrap banawe
Soon in...
Speedlab
and Drop It
October 7th, 2007 02:39 PM #23
Yup. Just talked to Ferman at Speedlab... he says that some people recommend it over Motul (feels too think at high temps, supposedly). I think I'm willing to go with the 10w40 for my next oil change. Just need to find a way to get this past the casa (they frown upon non-Shell oils)... but as I'm at 75,000 kms, I'm not sure I want to go through the hassle of using casa oils for another 25,000 kms of my warranty.
- Nov 2003
- 3,849
- Oct 2004
- 278
October 7th, 2007 08:35 PM #25Temperature surely is a factor there on the tests done... Di naman magkakaroon ng sugat yung metal kung walang friction - which leads to high temperature build up...
Eto nga pala site ng Royal Purple...
http://www.royalpurple.com/prodsa/auto.html
- Nov 2006
- 263
October 8th, 2007 01:23 AM #27been an avid user of royal purple for a long time.it does cost more than your conventional motor oil but getting an extra 10HP(proven already by alot of friends ran on dynos and TV car shows like horsepowerTV) its worth every penny i spend.
used for my engine oil,rearend differential and trans fluid.
October 8th, 2007 06:12 PM #28
Oooh... nice read.
I'm definitely going to try out Royal Purple the next time around (1000 kms to go!)... my fuel consumption also slightly decreased while using Motul too.
October 9th, 2007 12:01 AM #29
oppss... parang pareho tayo... di din ako masyadong satisfied sa motul oil na nilagay ko during my last change oil.... parang napansin ko din yung slightly decrease sa fuel consumption. I've been using mobil 1 eversince and I think it's time for me to try that Royal purple. kahit na 8K palang ang tinatakbo ng motul ko ay parang gusto ko ng palitan ng bagong oil.
- Nov 2003
- 3,849
October 10th, 2007 08:32 AM #30niky, dang... tagal nyan ah!
deedee, i doubt the 10hp is super accurate. it depends on the size of the engine to begin with but gains like those are more on the big engines/diesels.
mazdamazda, what are the viscosity req of your rav? wanna try out the 30 viscosity oil? check the manual muna kung pwede
Xiaomi E-Car
