Page 4 of 15 FirstFirst 1234567814 ... LastLast
Results 61 to 80 of 296
    #61
    Quote Originally Posted by happy_gilmore View Post
    instead of buying surplus shocks wherein you are not sure kung ok pa yung shocks na makukuha mo o kung kelan masisira, just have them repaired at zee or cruven for i think 800++ each. may warranty ka pa ng 1 year.
    700 yung convert/refill then 100ea for labor. the nice thing is adjustable pa yung psi ng shocks mo-- they initially pump 50psi in and then you can have them adjust it to smoothen the ride. 6mos po yung warranty.
    I had mine converted at their Cubao shop and I'm very happy with the result but it's a little bt stiff so i'll probably go back to the shop in a week's time.
    Sulit talaga. Saved me almost 8k for shock replacements and other under chassis repair.
    Nakasabay ko sa shop yung isang repeat customer-- he had his shocks converted 2yrs ago and ok pa daw.
    Feb 2007
    #62
    Additional information:
    Disributor ng kyb shocks in the philippines:
    ChuanLam Auto Supply
    2815 Jose Abad Santos Avenue,
    Tondo, Manila, Philippines 1012
    Tel.: (632) 253-4047 to 48, 253-4198
    Fax.: (632) 253-1335
    http://www.chuanlam.com/kayaba/index.htm
    Feb 2005
    #63
    just changed my two front shocks, put kyb as what many had recommended. ok naman ang feel nya.
    next is lowering spring kasi di masyado maganda tingnan na mas malaki ung space sa harap compare sa likod, magkano damage dito and ano ma recommend nyo. thanks
    Jul 2006
    #64
    anu po bang klaseng shocks to?
    from corolla 97 ae 101. sa rear sya nakalagay
    #65
    magkano na ba ang mura shocks ngaun,tight budget kasi, replacement sana corolla 94 gamit ko, ung rear sana, anu recommend nyo guys? kyb na din ba, lam nyo ba price nyan ngaun??
    Apr 2005
    #66
    around 2,200 sa prens sucat. kyb brand. gas.
    Feb 2007
    #67
    Guys I have affordable, high quality and brand new shock absorbers For Sale!!! The brand is Hankuk Made in Korea. The following are the shock absorbers available:
    HYUNDAI:
    Hyundai Excel Front (Fluid Type)
    Hyundai Elantra Rear (Fluid Type)
    Hyundai H100/Grace Front and Rear (Fluid)
    Hyundai Starex Front and Rear (Fluid)
    KIA:
    Kia Besta Front and Rear (Fluid Type)
    Kia Pregio Front (Gas Type)
    Kia Pregio Rear (Gas Type)
    Kia Pride Front Shocks
    Kia Pride Rear Shocks
    MB100:
    Front Shock Absorber (Gas Type)
    Rear Shock Absorber (Gas Type)
    TOYOTA:
    Tamaraw FX Wagon Front (Fluid Type)
    Tamaraw FX Wagon Rear (Fluid Type)
    NISSAN:
    Sentra B14 Front Shocks (Fluid Type)
    Sentra B14 Rear Shocks (Gas Type)
    ISUZU:
    Hilander/Crosswind Front Shocks (Fluid)
    Hilander/Crosswind Rear Shocks (Fluid)
    MITSUBISHI:
    L300 Front Shock Absorber (Fluid)
    L300 Rear Shock Absorber (Fluid)
    For price inquiry and order of the parts, just txt or call me at 09177448113. You can pick up the parts at Makati Cinema Square Mcdonalds Parking.
    Thank you.
    Jay C.
    09177448113
    Mar 2003
    #68
    pareho ba front and rear shocks ng hyundai grace/h100 may spare rear oem shocks pa kasi ako at baka puwede pa ipakabit sa front?
    Nov 2007
    #69
    I would like to ask your advice regarding my Honda CivicVTI 2001. My left front shock have leak sabi kailangan na daw palitan. Ask ko lang kung okay ba yung KYB na replacement? Di ba makakaapekto yun sa performance nung car? Wala po kasi ako masyadong alam kasi babae ako sana bigyan niyo ko ng advice, di kasi ako maka-decide. Yung original sobrang mahal. And, Okay din po ba yung Cruven, maayos din po ba sila magtrabaho? Sang branch ba maganda - cubao or makati?
    #70
    tanong ko lang bro... yung bagong install mo na two front shocks, gas o fluid? kasi kung maglolowering spring ka, dapat gas ang ininstall mo.
    #71
    Quote Originally Posted by lynne_santos30 View Post
    di makakaaffect sa performance ng oto mo yung KYB. if your stock shocks are fluids, replace it with fluid shocks too. or if you want to have it more durable, replace it with gas. yun nga lang, medyo stiffer ng onti ang ride mo. kung sensitive ka, may onting difference ang ride ng gas and fluid shocks.
    ok din ang cruven kung medyo tight budget ka, pero kung talagang wala kang alam sa cars, i would recommend replacing it with brand new ones, hindi reconditioned. may sasabit at sasabit minsan eh.
    and since yung sa oto mo, ang nakitang may leak is yung left front, you have to replace the front right too. don't replace only the left one, hindi papantay ang tindig ng oto mo. tsaka may effect sa ride quality.
    #72
    Quote Originally Posted by X-isle View Post
    how tight is your tight budget? kung talagang tight, just have your shocks repaired/refilled at cruven or zee.
    Sep 2006
    #73
    san ba ung cruven sa cubao? and pano malalaman kung kailangan na palitan ung shocks? parang may tulo kasi sa front left wheel ko.hirap pa naman ng honda,mahal parts....
    #74
    Quote Originally Posted by MasterZerg View Post
    Bgy Bagong Lipunan, Crame, Cubao.
    http://cruven.tripod.com/mapcrame.jpg
    Nov 2007
    #75
    Thanks a lot!
    #76
    hey guys if your looking for cheap kayaba shops ... pm me i will give you the cheapest price ... if you don't believe me try calling or pm me
    BANAWE AUTO SUPPLY
    regy
    #77
    Kung tight ang budget mo ay kyb is one of the good option. Pero mas maganda yung OEM shocks pero more than double yung price nya. Kay CJ sa may vito cruz makati ako bumibili ng OEM honda parts. bilis yata talaga masira ng shocks ng ES, yun kasing ES sa garahe 2001 model tapos after 3-4 years ay pinalitan ng lahat ng brand new shocks, di naman masyado gamit yung kotse at konti lang lagi ang sakay. Yung front shocks ng EK 98 ko ay orig pa din until now at wala pang leak. pero yung rear ay naka nitrogen sya at more than 2 years na sya na naka ganon pero every year ay pinapa refill ko ng gas. 100 psi ang pinapa lagay ko, pero balak ko na din palitan ng brand new kyb gas shock sa next maintenance ko.
    #78
    meron pa kayang KYB shocks for 1984 ford Laser kasi kakapalit ko lang last october at sa west ave. pa ako nakabili ng brand new KYB rear gas shocks ko for my 1984 ford laser wala na silang pang front ano kaya replacement para sa front shocks ko kasi sa box ng nabili kong rear shocks is mazda 323 ibig sabihin yung yung alternative nya
    #79
    Got my KYB Excel-G shocks from here din. Pero mga P3K+ for an '03 Camry. Noticeably stiffer yung KYB Excel-G compared to OEM (Tokico) shocks, especially now that I'm on lowering springs. Thing with that though was the OEMs, which rode a bit smoother, lasted only about 2 years and cost about P10K each. You could almost buy 3 Excel-Gs for the same price, kaya pagtitiyagaan ko na lang to hanggang mejo lumambot na.
    #80
    Would anyone know the stock shocks for Corolla 96 gli? Gas or Fluid? I've been wanting to have my shocks replaced but delayed doing so coz when I called the casa last year they quoted me the ff prices:
    Front Left - P5949, Right P6383
    Rear Left - P6674, Right P6637
    Labor - P825 per shock.
    I find it too expensive so I called my suking auto shop and they said that they don't have original shocks, only KYB. (Fluid Type P2,100 and Gas Type P2,400) - Price quoted last year
    The last time I had my car checked (around 0CT 07) by the mechanic at the auto shop, he said that the shocks were still be okay but just this week I noticed that the ride has become rough/matagtag on the driver's side. If the front shocks are damaged already, do I replace just the front shocks or would it be better to replace the rear as well (kahit di pa sira)? Does anyone know where I could buy original shocks for my corolla? or would KYB do na?
shock absorber replacement
