Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
    Apr 2011
    #21
    update: nawala yun grinding sound after ko palitan ng hardware kit. sana maganda ang result. obserbahan ko parin. thanks sa mga input guys.
    Apr 2011
    #22
    as usual bumalik nanaman yun brake noise. oh well. hopeless na talaga auto ko
    Feb 2009
    #23
    Quote Originally Posted by sn0wbLind View Post
    follow the recommendations in the previous posts! your car was made by man, it can be repaired, remade, modified or altered by man. nothing is impossible to fix when it comes to cars to put her back in the road
    Aug 2009
    #24
    having the same predicament with my 7g galant. almost all in the previous threads were done but to no avail. maximum tolerance to date, hayyyz.
    Apr 2011
    #25
    nag research ako sa net.. since may ABS yun sentra ko..pwede din daw panggalingan ng sound yun.. pero pano ko malalaman na sa abs ang culprit?
    *9701
    ganyan din ba problem mo?
    Feb 2009
    #26
    *9701
    in the process of possibility elimination that the ABS is causing your symptoms, disable the abs by removing the abs fuse. the brakes revert back to foundation hydraulic brakes with vacuum assist.
    Apr 2011
    #27
    Still no lock with that abs fuse trick
    Feb 2009
    #28
    you described two noises. is it both screeching and grinding? using common household noises, use a good known similar noise for comparison. check beyond the brakes if you have tried most of the common brake repair procedure. it might be worn out suspension bushings or wheel bearing that is making noise. do a visual inspection if there are metal shavings around the suspected noise area. check for tightness of the fasteners that may have been disturbed. insufficiently torqued fasteners make that noise. the mating surfaces between the rotor and the hub must be free of debris. the mating surfaces between the caliper bracket and the steering knuckle must also be free of debris and torqued to specs
    Apr 2011
    #29
    sir parang crunching metal sound and tunog nya
    Feb 2009
    #30
    have you checked the wheel bearings and the brakes splash shield?
screeching/grinding sound when braking
