help mga sir
been dealing with this problem for awhile now. eto yun mga nacheck ko and nagawa
rotors - ok pa naman daw sabi ng mekaniko smooth pa. kakapalit ko lang 1 year ago
brake pads - bendix general ct (sabi ng isang mekaniko na pwede eto ang culprit pero hindi niya ko masagot pag tinatanong ko kung bakit yun kabilang caliper hindi maingay)
nagpalit ng surplus caliper - nawala ng one week then bumalik ulit ang grinding/screeching sound
caliper pin - pinalitan ko bago. nawawala then bumabalik ulit
pag madiin ang brake wala pero pag yun padampi dampi lang. ang lakas ng tunog/
naiipit talaga ako dito sa problem na to. dami ng napalitan hindi parin nawawala hehe
siguro pag may budget na ulit papalitan ko rotor or pads na din. (maybe ferodo brake pads) kung may mahanap.
car is sentra series III
.beri panny dat wan. the objective of washing the machined surface with soap and water is not for sanitation. it is for removal of unwanted powdery metal from machining. if you resurface the rotors, or deglaze the engine block cylinder, or lap the valves (grind valves as many people call it), you have to remove the unwanted remnants of the machining process. in your case, the cast iron dust if not removed, will cling to the brake pads and cause the brake squeal because of the sliding cast iron brake rotor and the cast iron dust coated brake pads making friction.
Thanks..
