Results 1 to 9 of 9
September 6th, 2009 05:54 PM #1
hi fellow tsikoteers sana someone can help me on this on what is the best thing to do. kasi yung nabili ko pong car is lowered, so low sa front as in tingin mo palang ay sayad na sa fender. Everytime i turn kapag uneven ang road surface such as uphill and downhill ay sumasayad gulong ko sa fender. ano po bang ginagawa dun para maiangat ng konti? change spring ba or what? btw 205/45/16 tires ko tapos kulay dilaw po spring.
September 6th, 2009 10:00 PM #2
most probably its the springs - tire offset combination. if you would want it, you can return your car to stock vehicle height. bili ka na lang ng original spring.
another option is using a lifter.
September 6th, 2009 10:14 PM #3
pagbinalik ko po sa stock height. springs lang po ba papalitan? ano po ang lifter? which is more advisable? thanks
September 6th, 2009 11:52 PM #4
replace na lang the springs with stock ones. more advisable and safer, though balik na orig na tindig ng auto mo bro. if lowered din ang likod, you have to lift it too. parang nakatingala yan...
regrading sa pagsayad ng gulong sa fender, mali ang wheel offset, too deep na nakabaon ang mags sa wheel well, di ko lang sure what ang remedy dito, pero i think its with the mags, its an incorrect rims for your car's wheel wells/fenders. anyways, you can try bolting it with longer bolts(male) and add a spacer/adopter, urong lang onti ng palabas yung rims mo. or have a new set of rims
September 7th, 2009 08:34 AM #5
May disadvantages po ba ang lifters?... may additional maintenance po ba?... mag-cause po kaya sya ng langitngit?
TIA!
September 7th, 2009 10:58 AM #6
September 7th, 2009 11:13 AM #7
^^^ pag magtuturn lang po kung ang daan ay medyo pataas or pababa. if ibalik ko sa stock height baka hindi bumagay ang gulong ko 205/45/16 kasi.
November 9th, 2012 06:57 PM #8
I have this same problem ngayon sa Suzuki Alto ko.
Eto po scenario. Last August Pangasinan trip, 80-90kph ave speed, tires ko stock lang 145/70 goodyear, 5 passengers (including me total weight est. 335 kilos pati gamit) walang sayad kahit high speed sa small bumps.. November trip same average speed, tires 175/60 nankang, 5 passengers din estimated weight 315 kilos mas payat yung isa at mas konti na gamit na dala, SUMASAYAD rear tires ko, napansin ko may mga kayod na, akala ko kc yung mga de-latang dala namin ung natunog kapag nadadaan sa small bumps at high speed, yun pala sayad na rear fender sa rear tire.. nagtataka ko bakit sumasayad sya unlike before na heavier load pa dala ko.
Stock tire was 145/70/R13 vs New set of tires 175/60/R13. Computing the sidewall height, it would be 101.5mm (stock) vs 105mm (new). Is the 3.5mm difference enough para sumayad na agad yung new set of tires.
I have suspicion na shocks ko ang may problema. Since tila bouncy sya lalo na pag 4 to 5 passengers sakay. 7,000 kms pa lang natatakbo ng car ko and nakapaginstall na rin ako ng spring cushions last August pa.
Opinions is highly appreciated.
February 27th, 2013 06:01 AM #9
Solved the "sayad" issues ng previous ride ko sa rear. Installed O-sulee spring cushions sa likod. My previous car (lowered by 1.5") can now seat 5 adults regardless of weight without worrying na sasayad sya. Plus it solved the aesthetic issue na medyo nakatingala sya. Pantay na ngayon ang stance ng front at likod nya.
Xiaomi E-Car
