Results 1 to 9 of 9
    Jun 2006
    hi fellow tsikoteers sana someone can help me on this on what is the best thing to do. kasi yung nabili ko pong car is lowered, so low sa front as in tingin mo palang ay sayad na sa fender. Everytime i turn kapag uneven ang road surface such as uphill and downhill ay sumasayad gulong ko sa fender. ano po bang ginagawa dun para maiangat ng konti? change spring ba or what? btw 205/45/16 tires ko tapos kulay dilaw po spring.
    most probably its the springs - tire offset combination. if you would want it, you can return your car to stock vehicle height. bili ka na lang ng original spring.
    another option is using a lifter.
    Jun 2006
    pagbinalik ko po sa stock height. springs lang po ba papalitan? ano po ang lifter? which is more advisable? thanks
    Quote Originally Posted by step22 View Post
    replace na lang the springs with stock ones. more advisable and safer, though balik na orig na tindig ng auto mo bro. if lowered din ang likod, you have to lift it too. parang nakatingala yan...
    regrading sa pagsayad ng gulong sa fender, mali ang wheel offset, too deep na nakabaon ang mags sa wheel well, di ko lang sure what ang remedy dito, pero i think its with the mags, its an incorrect rims for your car's wheel wells/fenders. anyways, you can try bolting it with longer bolts(male) and add a spacer/adopter, urong lang onti ng palabas yung rims mo. or have a new set of rims
    May disadvantages po ba ang lifters?... may additional maintenance po ba?... mag-cause po kaya sya ng langitngit?
    TIA!
    Quote Originally Posted by Macky View Post
    TIA!
    Solved the "sayad" issues ng previous ride ko sa rear. Installed O-sulee spring cushions sa likod. My previous car (lowered by 1.5") can now seat 5 adults regardless of weight without worrying na sasayad sya. Plus it solved the aesthetic issue na medyo nakatingala sya. Pantay na ngayon ang stance ng front at likod nya.
    Quote Originally Posted by aejhayl17 View Post
    tingin ko bro, it a lowering issue dahil sumasayad si TS pag umaakyat o bumababa.
    Jun 2006
    ^^^ pag magtuturn lang po kung ang daan ay medyo pataas or pababa. if ibalik ko sa stock height baka hindi bumagay ang gulong ko 205/45/16 kasi.
Sayad sa fender
