Results 11 to 18 of 18
- Oct 2007
- 120
January 9th, 2008 05:58 PM #11Niky, Here's an interesting article on run flats http://www.nytimes.com/2007/03/11/au...bjects/T/Tires
March 14th, 2022 12:09 PM #12
2022...
anyone here using Run Flats on their non-European daily driver?
- Sep 2021
- 901
March 14th, 2022 01:36 PM #13I've read through the previous comments (from 14 years ago).
All I can say is given the cost of these tires, para lang talaga ito sa mga cars of VIPs etc .(with armoring/bulletproofing) so they can continue driving for a certain distance & speed even if the tires are shot at.
Pero kung para maka iwas lang sa hassle na magpalit ng gulong & vulcanizing... nah.
I wonder if these tires can be vulcanized/repaired (will look it up nga- na curious tuloy).
BTW, I know may mas practical variation din for general public use din ata ito dati (like 2 thinner tires on a special rim- may billboard nito sa E Rod. between Gilmore & Hemady) but it never became mainstream. Baka sobra mahal.
Extra aquaplaning resistant din daw because of the deep channel between the twin tires...
March 14th, 2022 01:39 PM #14
- Sep 2021
- 901
March 14th, 2022 01:44 PM #15
March 14th, 2022 02:20 PM #16
March 14th, 2022 02:31 PM #17
What Egan101 said. Expensive. Matagtag pa. The reinforced sidewalls have little to no give compared to normal tires. You'll also need to have a TPMS installed so you don't go around wrecking the tire by going over the speed/range limit when it is flat. Di kasi masyado ramdam sa RFT kung flat na. Finding a replacement is also hard as most importers only keep a few in stock. Madalas walang stock.
Luxury cars need to have these because they have removed the spare to make way for extra storage space.Last edited by Wh1stl3r; March 14th, 2022 at 02:40 PM.
March 14th, 2022 03:12 PM #18
I actually saw this vlog kaya bigla kong naisip kung normal na ba run flats...
looked for the video. it would seem, according to the video, the car in question was purchased by...
China cars
