Results 1 to 2 of 2
June 15th, 2012 11:19 PM #1
Although you have "lifted" the car's suspension, it still does not reduce the added weight.
In the medium to long term, the springs will sag/compress and the shock/dampers will wear out sooner than later (due to extra work they have to do with the weight of the amps/speakers/box. The same goes for the rubber bushings in the rear suspension.
Also, your car's fuel economy will go down and the brakes will wear out a bit faster with all the extra weight you are carrying.
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
Rubber boot question (repair or replace)
