Results 1 to 10 of 32
- 54,226
March 12th, 2020 02:37 PM #1the rubber boot has no structural function.
the objective of the rubber boot, is to protect the metal parts of the joint from rusting or wearing out faster than it normally does.
if the joint is still good, i.e., no noise or excessive free play, then you can go on using it, as is.
you can replace it when it starts acting up (above).
kasi, my suspicion is, you can not replace that boot. you have to replace the entire assembly.
might as well maximize it, before replacing it.
good luck.
tell us what happens.
and yes. the un-zoomed picture is much better.
in the past,
we have continued using the joint, even if the rubber boot had already torn.
tumatagal naman yung joint, before it starts acting up. something like a year... maybe more...Last edited by dr. d; March 12th, 2020 at 02:52 PM.
- Feb 2014
- 2,698
March 12th, 2020 05:31 PM #2inject grease inside the boot. then patch the hole w/ a bicycle tube patch. get a small and flexible one like Maruni
but that's just delaying the inevitable
March 12th, 2020 06:26 PM #3
I thought I'd address the 2nd elephant in the room.... why is the hub assembly and lower arm soaking in oil? Is the strut/damper leaking as well?
- 54,226
March 12th, 2020 08:06 PM #5
- Feb 2020
- 17
March 13th, 2020 09:37 AM #6That looks like a ball joint boot; it prevents dust and water getting into the joint. If the joint is still in good condition, replacing just its boot is a nice option. You can try 'em mechanic guys in Banawe as they might just find a boot from a recovered joint.
Cheers!
- 54,226
March 13th, 2020 09:49 AM #7most of these boots are not cheap to replace.
while the rubber boot itself might cost only so much, the labor involved might cost more than the part being replaced. babaklasin kasi yung buong dulo...
as i recall, the classic VW air-cooled axle boot was designed for ease of replacement. it had a longitudinal opening that is closed in place by multiple bolts and nuts. parang butones ng polo shirt.
March 13th, 2020 10:13 AM #8
Those days....Those cars....Dealership survival wasn't conceived/schemed yet, doc.[emoji4]
Look at them today....mod a lil, miss a PMS, void the warranty. Electronics, diagnostics, Make-badged lubes/fluids, CVT, planned obsolescence.....so many tricks up their sleeves. Cars are no different from cellphones now.[emoji16]
March 13th, 2020 10:40 AM #9
- Aug 2020
- 2
August 17th, 2020 11:50 AM #10replace sir, kakapalit ko lang ng boot, sabi kasi ng mekaniko ko, mas mainam daw palitan na para hndi pasukan ng dumi
Hyundai Santa Fe GLS 2024
Tsikot Hyundai Registry
